Hey. I'm trying to render a simple animation scene to disk. When I load scene into IPR Window, everything rendering correctly. But if I press "Render to Disk" with "Render Frame Range", in final output, I just get first frame with no update for other frames (125 rendered frames look like first one). I checked another file, everything is OK. What is the problem?
My Houdini version is 16.0.504.20
Octane version is 3.06.0.0
Render problem
- Alexander_Golubeff
That was actually a problem. ROP node was set to "Update scene". I switched it to "Full scene reload". Now it works!juanjgon wrote:Hi,
It sounds like a scene update problem. What is the configuration of the ROP node related to the render mode? Full scene reload or update mode?
Thank you!
