Page 1 of 4
Minor exporter update
Posted: Wed Nov 16, 2011 9:39 pm
by SamPage
This minor update just introduces two new features. The first is some people have been reporting problems getting Octane to start when exporting from the newer Rhino V5 betas. This exporter includes a new command, OctaneExportMeshes which will let you choose where to stick your OBJ, then will print on the command line a string you can use to launch Octane with the camera and target positions that you are using in the current viewport.
This version also now has the option (under OctaneOptions) to not export Rhino camera up vector (this should now be off by default, so if you liked it you are going to have to turn it back on).
Let me know if you have problems,
Sam
Re: Minor exporter update
Posted: Fri Nov 18, 2011 12:35 am
by C3Design
Sam! Your the man!!! Thanks for your Rhino exporter efforts. I use it a lot and have done some fine rendering work in Octane and so appreciate having the tools to do so.
Posted: Fri Nov 18, 2011 5:09 am
by jitendra
Thanks.. This is great work !!!
Have you thought about developing plugin for rhino ?
Posted: Fri Nov 18, 2011 5:15 am
by jitendra
I have this error coming..
Can you check the plugin again ?
Posted: Fri Nov 18, 2011 5:38 am
by SamPage
Mmm, lovely. How many video cards do you have in the machine you are getting this error on?
Also, can you look to see if you have this file:
Win7 / Vista:
C:\Users\[User]\AppData\Roaming\OctaneExport\exportOptions.ini
Win XP:
C:\Documents and Settings\{user}\Application Data \OctaneExport\exportOptions.ini
If you do, can you post the contents?
Sam
Posted: Sat Nov 19, 2011 6:04 am
by jitendra
I am running with two graphics cards.
GTX 470 + GTX 580.
There is no file under C:\Users\[user]\AppData\Roaming\OctaneExport
Thanks.
I am using Rhino4 SR9.
Posted: Fri Nov 25, 2011 5:06 pm
by Daniel79
I have a question:
You can export various positions of camera?
if I want to update the obj file in octane (updated model, different camera...), what happens to other "cameras" position?.
I try to reload obj whit different cameras position but the render, but the render keeps the initial position! what i wrong? How do I upload different position of camera without re-rendering all?
Thanks a lot
Posted: Tue Dec 20, 2011 9:59 am
by steffen_l
Hi Sam, i get this strange Error in V5, exportOptions.ini looks like this:
Path=C:\Program Files\Refractive Software\OctaneRender 1.025 beta2.52\Octane.exe
nSamples=0
bRenderOnStart=True
card=;False
bCamTilt=False
any idea?
thanks for your great work! Steffen
Posted: Tue Dec 20, 2011 10:28 am
by Refracty
Thanky for the good work Sam.
It would be very cool to have a export all "named views to ocs. cameras" option.
Posted: Wed Jan 04, 2012 4:04 pm
by SamPage
Sorry for the lack of replies. It is looking like the errora are cropping up in the VBscripting engine itself. McNeel is still trying to hammer this one out. The obvious solution is to rewrite it using a different language, which should probably be done, it is just a mater of finding the time at the moment.
Sam
