Page 1 of 2
				dark water
				Posted: Tue Oct 04, 2011 1:45 pm
				by merid888
				hello i would like know how i can create a natural white water clear becouse mine is so dark i been used material livebd and is the same result
i add image, thank you for your read this profile
				Re: dark water
				Posted: Tue Oct 04, 2011 11:01 pm
				by kubo
				use the little trick of adding some opacity to the specular material of the water, for a bonus, use a texture mix in the opacity with a noise generator and put something like 0,9 and 0,6 in the values, play with the scale of the noise and you'll get fake caustics on the go....
				Re: dark water
				Posted: Wed Oct 05, 2011 7:26 am
				by Sportler
				Also, your absorption is like 0.0001, which means that most of the light is absorbed after it has passed through 0.0001m of water, more accurately: 0.1mm of water, try increasing it
				Re: dark water
				Posted: Wed Oct 05, 2011 3:42 pm
				by merid888
				gracias kubo por tu comentario pero donde encuentro este ¿ noise generator ?
thank you sportler i will the change and i`ll upload image
regards
in the image of palms and water mirror i did this texture with the version 2.46 and i don't had problem just was an specular with the values 1.333 and nothing more i don't know why i can't do the same texture with 2.52 version
				Re: dark water
				Posted: Wed Oct 05, 2011 9:38 pm
				by kubo
				you were using an HDRI to light the scene in the first one, on the second one you are using the sun.
The noise, use a turbulence node attach it to the first slot on a mix texture node, and play with the other 2 values till it looks correct.
				Re: dark water
				Posted: Thu Oct 06, 2011 11:54 am
				by merid888
				hi kubo is not an hdri is just the background white of the octanerender, none texture
i'll try using your comment
regards
				Re: dark water
				Posted: Thu Oct 06, 2011 5:45 pm
				by kubo
				well, doesn't matter if it's an HDRI or a white texture, same applies. The sun right now has a different aproach and as long as you don't do the opacity trick with it light won't go thru your objects.
				Re: dark water
				Posted: Fri Oct 07, 2011 4:55 am
				by merid888
				thank you again kubo, you are so friendly i'll upload image to see the caustics in the water, how do you know much about this program ?
regards
				Re: dark water
				Posted: Fri Oct 07, 2011 9:22 pm
				by merid888
				i add image the first without sun and second with sun
i add water values too
i would like read some comments
thank you
				Re: dark water
				Posted: Sat Oct 08, 2011 8:39 am
				by gilfanovruslan
				The Sun is very blue, but without the blue sun water in not blue
