Page 1 of 2
OctaneRender for DAZ Studio 2025.6.0 - 409 [Stable][Obsolete]
Posted: Wed Jun 10, 2026 11:18 pm
by BK
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for DAZ Studio - TEST (ie. pre-release) and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date.
2) Make sure you are running the latest version of the OctaneRender for DAZStudio plugin.
3) If you experience a DAZStudio crash - deleting C:\Users\[username]\OctaneRender\Data\OctaneRender_settings.oczdb may resolve the issue.
This also resolves the "COULD NOT INITIALISE IN-MEMORY DB!" error on startup and a number of other issues.
4) If the Save button is disabled when using the Final button - disable the Final button and in Render settings select the SuperScope (2:1) Size / aspect ratio and drag the Viewport height or width until you reach required resolution.
5) If rendering an animation fails after 11 frames - make sure the DAZStudio viewport is visible when you render the animation.
6) If Octane materials are not loading when you load a previously saved scene - tick Preferences->Load OctaneRender materials from .duf user presets. If ticking this option does not stick between DAZStudio restarts, delete OctaneRender_settings.oczdb as per NOTE 3 above.
7) If you get a "Could not save a frame for X times!" - please search the forum for potential solutions.
8) If you get a "Bogus Scene Path" error - this is due to having an apostrophe in the filepath of a texturemap (so store your textures in foldernames which do not have apostrophes).
9) Octane panel title bar is off the screen and cannot be closed - click anywhere on the Octane panel and then press Alt-F4.
10) Rendering animation results in the scene emitter intensities changing - this is because rendering animations is done in "Final" mode, where meshes are merged. To resolve this, UNTICK the Preferences->Use Combined Mesh, or ENABLE the Surface Brightness pin on each of the emission materials in the scene.
11) Denoiser is not working - make sure you have a graphics card selected for Denoising in the System tab->Open Device Settings window, and that you are using the Path Tracing kernel.
12) Render artifacts near eyebrows - this is due to the eyebrow geometry going inside the head mesh surface. So morph, move or scale the eyebrows so they do not intersect with the head mesh.
13) Octane panes do not appear on the screen (ie. they open off the screen) - Main Menu Bar->Window->Workspace->Select Layout->Accept (you might choose a different layout to the current layout to make this work).
KNOWN ISSUES AWAITING RESOLUTION
1) Panoramic camera and OSL nodes are not currently supported.
2) Templating is not currently working for specular and roughness maps from Iray materials. - FIXED (please report any issues)
3) UDIM Tiles are not currently supported. - FIXED (please report any issues)
4) Some of the newer OctaneRender material and texture types are not supported. - FIXED (please report any issues)
5) VDB volume and volumetric spotlight nodes are not currently supported.
DAZ Studio Version
DAZ Studio 4.8 or later on Windows 8, 10 or 11 64bit
Important notes:
[*] The minimum NVIDIA driver version required is R528 (R572 for GeForce RTX50 Series)..
Network Rendering
For Network Rendering, you must use the OctaneRender Studio+ Node release from the Octane Standalone forums/download page which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Studio+ 2025.6 Render Node builds.
Support Issues
- Operating System (ie. Win 8, 10, 11)
- Amount of RAM
- Nvidia driver version
- DAZ Studio version
- The most important part of resolving a problem is being able to reproduce that problem. So please provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
Change logs
  • Fixed f-stop bug
  • Minor bug fixes and improvements...
Workflow to create OctaneVDB>Load the VDB via Parameters>Apply Volume medium>Render
The format of file names should be like this: the frame number should be padded by zeroes in front, and surrounded by dots. Like some_file.00014.vdb, some_file.00118.vdb, etc. Just select the first file of the sequence into a "VDB file" property.
There is one more property added to a new VDB node: "Frame offset". This may be needed if you have e.g. VDB-files' sequence starting with 0001, but your first frame to render is "0". In this case you set the frame offset to "1".
Please keep in mind, some VDB objects are really heavy for GPU-rendering. Thus, to not get your DAZ or other Windows processes crashed, it is a good idea to have additional GPU only dedicated for rendering, and all the GPUs that have monitors connected to them - completely disabled for rendering in Octane "Device Settings". Something like this:
FAQ
Q: How to change light brightness/color?
A: You need to assign a material to the light and adjust the emission of the material. You can do it either by dragging a material to the light in the Materials tab (similar to assigning materials to geometry) or by right clicking on the light and selecting menu item under "Create as new light source".
Q: How do I enable analytic light?
A: Create a point light (or linear point light, they are the same). Then turn on "use analytic light" in the OctaneRender settings.
Q: I selected "rectangle" light geometry, but light didn't change
A: "rectangle", "disc" and "cylinder" geometries are only supported for analytic lights
Q: I assigned emission material to the light, but it's still not visible
A: If the light is analytic, make sure the emission node is expanded (i.e. is a separate node, connected to emission pin). It's required for analytic lights to work.
Q: How to make light beams work?
A: 1) Set the light to be analytic, rectangle or disc shape, enable "use in post volume".
2) In render settings enable post processing and light beams
Download Links
Please feel free to report any issues you encounter.
Happy rendering
Your OTOY team
Re: OctaneRender for DAZ Studio 2025.6.0 - 409 [Stable]
Posted: Wed Jun 10, 2026 11:32 pm
by RGUS
Thank you so much for this.
I notice after install, the Version is 2025.6.0.409 Orime Beta. Does this mean other goodies are coming to the final release?
Posted: Wed Jun 10, 2026 11:44 pm
by BK
RGUS wrote: Wed Jun 10, 2026 11:32 pm Thank you so much for this.
Big thanks to Jim, he jumped from other task to fix this bug.
Sure, once stable enough we plan to integrate all the Octane goodies :D
Please feel free to let us know the most wanted feature !!
cheers
Posted: Wed Jun 10, 2026 11:57 pm
by RGUS
Jim deserves a pay rise.
Most wanted feature... support for strand-based hair... but I suspect that I'm dreaming too loud.
Thanks again for the support.
Posted: Thu Jun 11, 2026 2:07 am
by BK
RGUS wrote: Wed Jun 10, 2026 11:57 pm Jim deserves a pay rise.
Hahaha, true. Thank you for reminding about strand-based hair support.
We have created an internal request ticket.
Cheers
Posted: Thu Jun 11, 2026 4:04 pm
by Tugpsx
Thanks for the update. Will continue testing some more EmberGen VDBs.
Posted: Fri Jun 12, 2026 3:16 am
by Sorel
Hi BK, better strand hair support is also a big requested feature from myself (and many others I'm sure). I do have a couple of general questions though.
Now that Daz 6 is out, when do y'all expect to start porting the plugin to that version?
When can we expect a 2026 version of the octane plugin?
Posted: Sun Jun 14, 2026 11:05 pm
by BK
Tugpsx wrote: Thu Jun 11, 2026 4:04 pm Thanks for the update. Will continue testing some more EmberGen VDBs.
Sure, seems to work with EmberGen vdbs..
We just need to pick the right channels..
Let us know how things go!
Cheers
Posted: Sun Jun 14, 2026 11:30 pm
by BK
Sorel wrote: Fri Jun 12, 2026 3:16 am Hi BK, better strand hair support is also a big requested feature from myself (and many others I'm sure). I do have a couple of general questions though.
Hi Sorel,
Oh yeah, we have request ticket to support Daz 6. It seems Daz 6 integration is a big task as they have a lot of new features.
Sure, we plan to integrate Octane 2026 but we have no ETA yet.
cheers
Posted: Thu Jul 09, 2026 12:02 am
by huakiami
BK wrote: Wed Jun 10, 2026 11:44 pm Please feel free to let us know the most wanted feature !!
Hi BK -
Great to see continued support of the plugin. Support for rendering the strand-based hair as curves (instead of tessellated geometry) is definitely my most wanted feature as well. Now that we have VDBs it's really the only major feature in DazStudio that Iray supports which the Octane plugin does not, and we have no good workarounds (Iray decal nodes aren't supported by Octane for example, but we can easily use a composite material or geoshell to achieve the same effect). Frustration with hair is the only reason I sometimes still choose to work with Iray instead of Octane.
