OctaneRender™ for Blender 2025.5 - 30.11 FINAL Custom-Built Release [STABLE]
Posted: Mon Dec 15, 2025 5:47 pm
by azen
IMPORTANT NOTE: This will be the final "Custom-build" version of the Blender plugin. This Release will still be maintained for the foreseeable future, otherwise this is expected to be the very last version of the Blender plugin to use a custom-built version of Blender.
CHANGES SINCE LAST RELEASE
  • Updated to Octane 2025.5
  • Updated to Blender 4.5.5
FIXES SINCE LAST RELEASE
  • Minor bug fixes
HOTFIXES 30.11 (19/02)
  • Updated version number of Blender Octane Edition to 30.11
  • Refactored the OSL value structure to fix missing value issues in Blender 5.0
  • Added support for macOS 14.5 as the minimum requirement
You can read about new features of OctaneRender™ 2025.5 here:
viewtopic.php?t=85294
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 30.11 (4.5.5)
Octane Server - Studio+ Edition - 30.11
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
  • Your Hardware specifications (unless they are included in your signature)
  • A clear description of the issue you have found
  • Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
  • Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
