OctaneRender for HoudiniSolaris 2025.4.0.0 R1 [OBSOLETE]
Posted: Mon Nov 24, 2025 2:17 am
by BK
OTOY® is proud to announce the availability of the new DCC plugin OctaneRender for HoudiniSolaris 2025.4.0.0 release.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrates completely with Houdini 20.0, Houdini 20.5 & Houdini 21.0 Solaris.
OctaneSolaris builds supported by this release: 20.0.896, 20.5.613, 20.5.654, 20.5.684, 21.0.440
The OctaneRender for Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launching it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
-Houdnin Packages/json installation steps-
- Please create a folder inside Documents\houdini19.5 and name it as Packages
- Open notepad or any text editor and use these lines
    "enable": true,
    "env": [
            "OCTANE_AUTOSPAREPARAMS": {
                "value": 1
            "OCTVERSION": "PATH_TO_OCTANE_SOLARIS_Win64 FOLDER"
            "HOUDINI_PATH": {
                "value": "$OCTVERSION"
            "PATH": {
                "value": "$OCTVERSION\\bin"
            "PXR_PLUGINPATH_NAME": {
                "value": "$OCTVERSION\\dso\\usd_plugins"
- Then Save as OctaneSolaris.json
- Please make sure to disable the .env paths
- Please run **createPackageFileForOctane.bat** for the automatic Package installer for Windows OS.
New features
To learn more about the new features and improvements of OctaneRender 2025.4 and the Render Node app, please check out (Link )
Change log since last release
  • - Unified with OctaneRender 2025.4 for Houdini production (2025.4.0.0) viewtopic.php?t=85229
  • - Fixed OSL camera editor
Known bug: Houdini will crash when Lights switch from Point to disk or cylinder
Note: Click the link below to refer to the Important SOP to USD attribute conversion
https://www.sidefx.com/docs/houdini18.5/solaris/sop_import.html
Important notes:
[*] The minimum NVIDIA driver version required has been raised to R528 (R572 for GeForce RTX50 Series).
[*] The GPU version of Open Image Denoise is supported on Volta and Ada GPUs currently. The CPU version is used on devices with other models, and on macOS..
[*] The minimum version of macOS required is 14.5.[/b]
Linux Note
On Linux only default Houdini builds are supported.
This means that for Houdini 20.0, 20.5 and 21.0 gcc11.2 builds are supported.
Note: Please do not use Houdini 21.0.440 build for production yet. We are releasing it as an experimental and to collect bug reports.
Subscription Studio+ Downloads
OctaneSolaris [macOS](Link)
OctaneSolaris [Linux](Link)
OctaneSolaris [Windows](Link)
Demo Downloads
Happy GPU Rendering !!
Your team
OTOY
Re: OctaneRender for HoudiniSolaris 2025.4.0.0 R1
Posted: Mon Nov 24, 2025 7:11 am
by coresign
21.0.512 please
Posted: Sat Nov 29, 2025 11:41 am
by LocalVoid
The 20.5.613 version works, but the 21.0.440 on crashes on startup. M3 Max, Sequoia 15.6.1
Posted: Wed Dec 03, 2025 10:55 pm
by BK
LocalVoid wrote: Sat Nov 29, 2025 11:41 am The 20.5.613 version works, but the 21.0.440 on crashes on startup. M3 Max, Sequoia 15.6.1
Thank you so much for reporting this issue..
Would you please roll back to H20.5.x builds?
cheers
