OctaneRender 2025.2.1 for Houdini production (2025.2.1.0)
Posted: Thu Jun 05, 2025 3:41 am
This is a production release of the OctaneRenderâ„¢ 2025.2.1.0 for Houdiniâ„¢ plugin compiled with the Octane 2025.2.1 core. This 2025.2.1.0 release is available for the latest Houdini production builds on Windows x64, Linux, and macOS arm64.
Houdini production builds supported by this release: 19.5.805, 20.0.896, 20.5.550, 20.5.584, 20.5.613.
If you are not sure if your Houdini version is compatible with the plugin - just run it and you will see an error message in case of incompatibility.
Linux Note
On Linux only default Houdini builds are supported.
This means that for Houdini 20.0 and 20.5, gcc11.2 builds are supported, and for Houdini 19.5, gcc9.3 build is supported.
New features
To learn more about the new features and improvements of OctaneRender 2025.2.1, please check out the 2025.2.1 release post
Known bugs
On Linux, MPlay IPR may not be working. If you are having problems with it, please switch to QT5 IPR and disable "Render to MPlay" in ROP nodes.
Downloads
Release 2025.2.0.0 Studio+ license
Windows Houdini 19.5.805
Windows Houdini 20.0.896
Windows Houdini 20.5.550
Windows Houdini 20.5.584
Windows Houdini 20.5.613
Linux Houdini 19.5.805
Linux Houdini 20.0.896 (gcc11.2)
Linux Houdini 20.5.550 (gcc11.2)
Linux Houdini 20.5.584 (gcc11.2)
Linux Houdini 20.5.613 (gcc11.2)
Release 2025.2.0.0 macOS Prime license
MacOS Houdini 19.5.805
MacOS Houdini 20.0.896
MacOS Houdini 20.5.550
MacOS Houdini 20.5.584
MacOS Houdini 20.5.613
Release 2025.2.0.0 Demo version
Release Notes
RELEASE 2025.2.1.0
PLUGIN FEATURES AND FIXES:
From 2025.1.Beta_1.0, Octane plugin for Houdini uses Houdini package file. Each build ships a script (createPackageFileForOctane.bat for Windows, createPackageFileForOctane.sh for Linux and Mac) to help create the Octane.json file as below under C:\Users\<username>\Documents\houdiniXX.Y\packages on windows, ~/Library/Preferences/houdini/XX.Y/packages on Mac, or ~/houdiniXX.Y/packages on Linux.
Important Note
2024.1.0.2 fixed the problem that the layered material nodes cannot be loaded properly, however this fix affects all layered material nodes and OSL material nodes in existing saved .hip files. When loading a .hip file for the first time using this build, it's necessary to adjust the connections of these nodes. Once the file is saved with the updated connections, the issue will be resolved.
Common Issues and Solutions
- If the plugin doesn't work at all, set
- If you're missing
- If you are having any issues with the Deadline - please submit a support ticket to the AWS.
Happy rendering,
Your OTOY Team
Linux Note
New features
Known bugs
Downloads
Release Notes
RELEASE 2025.2.1.0
- Fix connection with Houdini dot node and subnet
- Fixed octane Render setup's OCIO default value not being set in the render settings node
- Revamped dive target now includes camera osl and global texture nodes in addition to the previous outputAOV
- Added a note in customAOVs
- Fixed wrongly linked global texture AOV
- Fixed issue where it was not working with spectron lights (and wouldn't ignore spectron lights in the tracing either)
- Added options to use image Alpha channel under opacity settings
- Fixed gradients not working correctly when more than 2 points
"enable": true,
"env": [
"OCTANE_AUTOSPAREPARAMS": {
"value": 1
"OCTVERSION": "<path_to_plugin_directory>"
"HOUDINI_PATH": {
"value": "$OCTVERSION"
"HOUDINI_MENU_PATH": {
"value": "$OCTVERSION/config/Menus"
"HOUDINI_SCRIPT_PATH": {
"value": "$OCTVERSION/scripts"
"PATH": {
"value": "$OCTVERSION/bin"
"PXR_PLUGINPATH_NAME": {
"value": "$OCTVERSION/dso/usd_plugins"
HOUDINI_DSO_ERROR = 2 in houdini.env and check for messages in the terminal.- If you're missing
libglut.so.3, install the freeglut package.- If you are having any issues with the Deadline - please submit a support ticket to the AWS.
Happy rendering,
Your OTOY Team
