OctaneRender™ for Blender 2024.1.Alpha.2 - 29.1 [TEST]
Posted: Tue Jan 30, 2024 12:19 pm
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
NEW FEATURES SINCE LAST RELEASE
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 2024.1.Alpha.2 here:
viewtopic.php?f=33&t=82826
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 29.1 (4.0)
Octane Server - Studio+ Edition - 29.1
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 29.1
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Refactor the camera panel GUI
- Support "Real-time" option in Viewport rendering
- Support "Use F-Stop" in Universal Camera
- Support the feature of copying node data when switching node types
- Fix Blender node menu problem in the Blender's Compositor and Geometry node tree editors
- Fix an animation render issue
- Fix the problem that property with default value may not be saved in the .blend
- Minor Bug fixes
Windows
Linux
Installation:
$ OctaneServer &Blender Octane Edition - 29.1 (4.0)
OSX (Metal)
DOWNLOAD
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
