OSL compile error with boolean widget
Posted: Mon Aug 14, 2023 8:43 pm
Hi, I found a problem with OSL compilation.
I've tested this in both "Octane Blender" (27.16 / 3.5.1) and with the add-on (27.16.3 / 3.6.1)
(I've also tested the OSL script in the Octane Node Graph, and Cycles, where it works fine)
The problem is that you can't have an int as an boolean widget, you can't have it enabled by default.
Relevant line ("full" example bellow and attached):
And it gives this error:
Example:
int use_a = 1 [[string label = "Use A", string widget = "boolean"]], // This DOESN'T work!
// int use_a = 0 [[string label = "Use A", string widget = "boolean"]], // This worksAnd it gives this error:
Traceback (most recent call last):
File "C:\Users\chris\AppData\Roaming\Blender Foundation\Blender\3.6\scripts\addons\octane\nodes\base_osl.py", line 439, in invoke
node.compile_osl_node(self.report)
File "C:\Users\chris\AppData\Roaming\Blender Foundation\Blender\3.6\scripts\addons\octane\nodes\base_osl.py", line 392, in compile_osl_node
reply_data = str(ET.fromstring(response).get("content"))
File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\python\lib\xml\etree\ElementTree.py", line 1342, in XML
parser.feed(text)
xml.etree.ElementTree.ParseError: not well-formed (invalid token): line 3, column 127
Error: Python: Traceback (most recent call last):
parser.feed(text)
xml.etree.ElementTree.ParseError: not well-formed (invalid token): line 3, column 127Code: Select all
shader Switch(
color col_a = 0 [[string label = "A"]],
color col_b = 1 [[string label = "B"]],
output color out = 0 [[string label = "Output"]]
if (use_a)
out = col_a;
else
out = col_b;
