OctaneRender™ for Blender 2022.1.1 - 27.12 [STABLE]
Posted: Tue Apr 11, 2023 7:55 am
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
NEW FEATURES SINCE LAST RELEASE
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 2022.1.1 here:
viewtopic.php?f=24&t=81415
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 27.12 (3.4.1)
Octane Server - Studio+ Edition - 27.12
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 27.12
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Upgrade to Octane 2022.1.1
- Support using the shared surface feature on multiple-GPU platforms
- Add "Static noise" in the Info Channel Kernel
- Add "Perspective correction" in the universal camera
- Fix background rendering crash
Windows
Linux
Installation:
$ OctaneServer &Blender Octane Edition - 27.12 (3.4.1)
OSX (Metal)
DOWNLOAD
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
