Texture path reference
Posted: Thu Mar 30, 2023 8:14 am
by mirocreative
Hey Everyone,
ran into an issue and can't really figure out what's going on. I have a scene originally set up for Mantra (Principled Shader) and I'm trying to reference base color texture paths from the Principled Shader using 'chs("texture")'.
Works fine for OGL preview in viewport, textures show up correctly, works as expected. However when rendering textures don't show up at all, replaced by black base color.
What did I miss? Any ideas welcome, thanks guys!
Chris.
Re: Texture path reference
Posted: Thu Mar 30, 2023 8:40 pm
by juanjgon
If you have a problem related to Solaris and the Hydra plugin, you should post it in the Hydra forum. This is the support forum of the main Houdini plugin.
viewforum.php?f=142
Posted: Fri Mar 31, 2023 6:52 am
by mirocreative
juanjgon wrote:If you have a problem related to Solaris and the Hydra plugin, you should post it in the Hydra forum. This is the support forum of the main Houdini plugin.
viewforum.php?f=142
My bad, Mantra principled shader instead of Karma. Problem still persists though, any ideas why referencing chs doesn't work at rendertime?
Posted: Fri Mar 31, 2023 7:38 am
by galleon27
You might want to share a simplified scene for us to debug.
Referencing paths works.
Posted: Fri Mar 31, 2023 7:40 am
by juanjgon
Yes, we are going to need an example scene to take a look at it here.
Posted: Sat Apr 01, 2023 10:16 am
by mirocreative
I'd love to share guys, but we have some commercial HDAs in the file
We managed to figure out, that the scene uses a rather strange string attribute to assign random textures for the book objects. While other renderers have no issue reading these, for some reason Octane can't read these when rendering - OGL viewport preview works fine.
We've dropped a message to the developer and waiting for an extended explanation how exactly the scene is set up.
Posted: Sun Apr 02, 2023 2:05 pm
by mirocreative
After talking to the HDA dev, it looks like Octane would need to handle material_override for the random textures to work. We have a thread from 2019 where it is mentioned as a planned core feature by juanjgon, but I guess it didn't make it to the production versions.
Case closed
