OctaneRender 2022.1.0.6 Solaris 19.5.534 - 022823[OBSOLETE]
Posted: Tue Mar 07, 2023 5:11 am
OTOY® is proud to announce the availability of the new DCC plugin OctaneRender for Solaris V2022.1 - for Houdini 19.5.534.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrates completely with Houdini 19.5 Solaris.
The OctaneRender for Solari's plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launching it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
-Houdnin Packages/json installation steps-
- Please create a folder inside Documents\houdini19.5 and name it as Packages
- Open notepad or any text editor and use these lines
- Then Save as OctaneSolaris.json
- Please make sure to disable the .env paths
New features
To learn more about the new features and improvements of OctaneRender 2022.1 and the Render Node app, please check out the 2022.1 release post
- Change log since last release[Test]-
https://www.sidefx.com/docs/houdini18.5 ... mport.html
-Known Issues-
- Solaris rendering extra beauty AOV with Octane node and currently investigating
- Light Linker is yet to be supported as we are investigating if we could assign the Octane light IDs internally.
However, the usual Octane light linking works as expected.
- Deep AOV is yet to support!
Studio+ Subscription Downloads
2022.1.0.6 - Houdini 19.5.534
macOS build Downloads for ARM64
Windows Demo build Download
Happy GPU Rendering !!
Your team
OTOY
"enable" : true,
"env":
"OCTANE_AUTOSPAREPARAMS" :
"value": 1,
//location to your octane folder (example below)
"OCTVERSION": "PATH\TO\OCTANESOLARIS\Win64FOLDER",
"HOUDINI_PATH" :
"value": "$OCTVERSION",
"PATH" :
"value": "$OCTVERSION/bin",
"PXR_PLUGINPATH_NAME" :
//if you have the solaris version installed
"value": "$PATH\TO\OCTANESOLARIS\dso\usd_plugins",
}- Please make sure to disable the .env paths
New features
- - Added Houdini 19.5.534 main plugin support
- - Fixed point instancer rotation
- - Fixed OctaneUI not responding on ARM build
- - Fixed demo output resolution
-Known Issues-
Your team
OTOY
