Page 1 of 2
C4D Octane Nodes are too limited compared to other DCCs
Posted: Sun Feb 19, 2023 9:04 pm
by SSmolak
C4D Octane nodes are too limited compared to Modo or Blender and even Octane Standalone.
1. In C4D most of the nodes have limited inputs for example Color correction is without hue input, Realtive Distance has only Transform input, Float has no inputs at all.
2. There is no way to use object positions like this :
https://youtu.be/9RTe-L_DB8A - ok yes there is link to object in Transform node but how to check other object orientation related to surface like light for example ?
Re: C4D Octane Nodes are too limited compared to other DCCs
Posted: Sun Feb 19, 2023 10:56 pm
by aoktar
too?
- Hue doesn't have texture input in Standalone also.
- You can put any object to Transform and connect to Rel. Distance
- What do you expect to connect to float? Is there something you can't do with C4D's capability with this?
Posted: Sun Feb 19, 2023 11:39 pm
by SSmolak
aoktar wrote:too?
In Standalone every node input can have basic connection - even for sun direction, that can be used for connecting more advanced nodes not listed here :
- hue_standalone.jpg (15.18 KiB) Viewed 2128 times
Blender version of Color Correction :
- blender_color_corr.jpg (10.01 KiB) Viewed 2128 times
Yes, right there is link to object in Transform node that works great except it is very hard to achieve good relation to object rotation like light - I must test it more maybe I'm doing something wrong.
Posted: Mon Feb 20, 2023 12:26 am
by aoktar
Value types are still available but not usable because of different type of connections. These are not very old and having some design limitation of node editor. Because of this I didn't completed this, will take time. Also you can do same tasks with C4D's xpresso/etc.. features. These nodes are just variables not rendertime parameters.
Posted: Tue Feb 21, 2023 12:12 am
by SSmolak
Right, almost everything can be done using xpresso but you know that this is little time consuming and needs to recreate/reconfigure for every new scene/materials.
This Sun Direction paremater from Standalone is very good. Some time ago I asked for feature like this but I didn't know that Standalone has this by default.
Posted: Tue Feb 21, 2023 10:32 am
by aoktar
SSmolak wrote:Right, almost everything can be done using xpresso but you know that this is little time consuming and needs to recreate/reconfigure for every new scene/materials.
I'll look to make some ways for easier connections.
Posted: Tue Feb 21, 2023 11:55 am
by ShivaMist
What are the plans for the node editor since you have not taken the route of the Cinema 4D Node Editor ? I remember seeing a demo of the new editor in standalone being based on the C4D Octane node editor a year ago or so
I also have a few comments on how to improve the node editor :
- The comment node is very useful for complex networks but it lacks some preset and the ability to set default colors
- Comment node could be automatically drawn around the selected nodes
- Having some routing option to avoid visual noodle soup (like Blender or Houdini)
- Having the ability to drag and drop an existing node on a link (same behavior as a new node is dragged from the side menu and dropped on any link)
- Improve the grouping feature with inputs, outputs and parameter promotion
- Grouping feature is also unstable and can cause crashes
- Auto Layout, Solo Node shortcut (add/modify)
- Chaos Node overhaul to support multiple textures inputs/outputs (avoids having to create a node for each PBR texture and link the parameters)
- Chaos Node HexTile mode
https://github.com/mmikk/hextile-demo
- PBR texture importer (i know there are scripts that do it but having it native with the possibility to setup custom tokens for pattern recognition would speed up the process 1Ox)
Posted: Tue Feb 21, 2023 12:06 pm
by aoktar
I'm not permitted to share all plans, but we are on the what you saw and much more.
Could you show examples for this?
Having ideas for making it easier
Posted: Tue Feb 21, 2023 2:07 pm
by ShivaMist
I understand, can't wait to know more about it!
Of course!
Node Framing and Rerouting in Blender :
https://youtu.be/TMz4ikl1yYM
Node Organization in Houdini :
https://vimeo.com/204582189?embedded=tr ... er=1723479
Node Drag and Drop (Works on newly created nodes but not on existing nodes)
Node Link Hover get a bit inconsistent when the nodes link is getting close to 90°
That's great
i'm down to give you some feedback when you'll have a test build ready!
Posted: Tue Feb 21, 2023 4:01 pm
by jobigoud
Chaos node is based on the same two papers the repo you pointed to is referencing. It's already using an hexagonal tiling of the plane.
