OctaneRender™ for Blender 2022.1 - 27.9 [TEST]
Posted: Thu Feb 09, 2023 1:05 am
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+/Enterprise License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
NEW FEATURES SINCE LAST RELEASE
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 2022.1 here:
viewtopic.php?f=24&t=80814
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 27.9 (3.4.1)
Octane Server - Studio+ Edition - 27.9
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 27.9
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Support rendering the Octane Sphere Primitive for the Alembic
- Added "Default Object Mesh Type" in the preferences panel
- Added the picking option in the Object Data node
- Added an Octane Node Converter in the Node Editor's right-click menu(Node Context Menu)
- Fixed the motion blur rendering issue when the camera is parented to a moving object
- Added "Old motion blur behavior" in the Motion Blur panel to emulate the old motion blur effect
- Assign the light to the Object Data automatically when creating Sun Light
- Fixed the rendering crash when importing image textures to a new scene
Windows
Linux
Installation:
$ OctaneServer &Blender Octane Edition - 27.9 (3.4.1)
OSX (Metal)
DOWNLOAD
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
