Info channel kernel puts out blank renders
Posted: Tue Feb 07, 2023 1:01 pm
by mikefrisk
When rendering with the info channel kernel it will put out black pngs. I set it to zdepth and hit render, in the render window it shows up fine but the saved png is black. Any ideas?
Re: Info channel kernel puts out blank renders
Posted: Thu Feb 09, 2023 1:01 am
by Lewis
Can you try TGA, TIF or EXR just to be sure it's not PNG saver or software what you use for looking PNGs...
Posted: Mon Feb 13, 2023 5:33 pm
by mikefrisk
As far as I know octane lw can only output png and exr. I tried exr, same results.
Posted: Mon Feb 13, 2023 5:41 pm
by Lewis
mikefrisk wrote:As far as I know octane lw can only output png and exr. I tried exr, same results.
I'am rendering TGA 32bit and JPGs since forever so not sure where that info comes from about PNG and EXR only ?
Posted: Tue Feb 14, 2023 6:29 pm
by frankmci
mikefrisk wrote:When rendering with the info channel kernel it will put out black pngs. I set it to zdepth and hit render, in the render window it shows up fine but the saved png is black. Any ideas?
Are you looking at the resulting image in a program that can display the higher bit depth data, and do you know how to check for it? The Z depth info may be there, but not being resampled properly to display on your monitor.
