LV is not triggered / updated after UV changes
Posted: Tue Oct 25, 2022 9:23 pm
by Delizade
When I change UV, LV is not refreshed properly. After a UV change sometimes LV refresh but correct UV information is not updated.
I have to hide and unhide the object to trigger it.
Is there any settings about it or any way to fix this?
Re: LV is not triggered / updated after UV changes
Posted: Tue Oct 25, 2022 9:41 pm
by aoktar
What kind of UV change you're doing? It will update if any change is detected. Otherwise will not because of unnecessary updates. This is internal workflow of it.
Posted: Tue Oct 25, 2022 9:50 pm
by Delizade
aoktar wrote:What kind of UV change you're doing? It will update if any change is detected. Otherwise will not because of unnecessary updates. This is internal workflow of it.
I just made some tests. Yes it refreshes normally but if the object is under a Subdivision Surface it doesn't.
Edit: and "Instance object" sometimes does not trigger
Edit 2: if object is under Symmetry, LV is not triggered as well
Posted: Tue Oct 25, 2022 10:11 pm
by aoktar
There are nothing to do for some specific cases.
Posted: Wed Oct 26, 2022 12:20 am
by Delizade
thank you
Posted: Fri Sep 11, 2026 8:18 am
by ceen
Bump:
Is the new symmetry object not being recognized by LV properly? I constantly have update issues with OctaneRender Studio+ 2026.2 (15010000)
Posted: Mon Sep 14, 2026 7:02 am
by bepeg4d
ceen wrote: Fri Sep 11, 2026 8:18 am Bump:
could you share an example scene that shows the issue?
ciao,
Beppe
