problems with volume spot light
Posted: Wed Aug 10, 2022 12:44 am
by coilbook
Hi Paride,
Do you have a sample scene with a volume spot light where it looks like in the image attached as a blue sport light.
It seems there is no connection between volume, light, light spot, cone size. Thank you!
Re: problems with volume spot light
Posted: Wed Aug 10, 2022 3:37 pm
by paride4331
Hi coilbook,
You can use the volumetric spotlight or a photometric spotlight that octane now supports.
Posted: Wed Aug 10, 2022 7:59 pm
by coilbook
paride4331 wrote:Hi coilbook,
Thank you. And photometric spotlight are only supported in 2022 version?
Posted: Thu Aug 11, 2022 12:26 am
by neonZorglub
Support for photometric lights is also available from 2021.1.5 - 22 / 23.
The photometric spotlight might be currently a bit more noisy than the Octane volumetric spotlight.
This will be improved in a future release.
When starting a new scene, the Octane volumetric spotlight is probably a better choice.
Note that you can have control of the 'hardness' of the light cone (as with the 2 angles of the photometric spotlight hotspot / Falloff),
using a 'Spotlight' map in the Distribution' of the black body emission:
See the red spotlight here:
spot03_hardness.zip
(90.35 KiB) Downloaded 124 times
Posted: Thu Aug 11, 2022 1:44 am
by coilbook
spot03_hardness.zip
Thank you!
