Takes trigger incorrect render kernal
Posted: Tue Aug 09, 2022 11:43 am
by boxfx
The attached project has 2 takes and 2 render settings. One take uses normal render settings (direct lighting kernal) and the other take uses some render settings with a kernel overwrite set to "info channels: Material ID"
When I select a take and press the usual "render to picture viewer" button, I get the correct lit render and material ID passes.
When I run the command "render marked takes to picture viewer", Instead I only get the material ID pass twice, the standard direct lighting kernel render is missing.
c4d 26.107
octane 2021.1.5
gf 3090, latest drivers
Re: Takes trigger incorrect render kernal
Posted: Tue Aug 09, 2022 12:03 pm
by boxfx
There is a workaround for anyone else that has this issue. Enable "overwrite kernel" for all render settings.
