Forest pack and render Layer ID pass.
Posted: Fri Jul 22, 2022 7:41 am
by HHbomb
I can't understand how to give FP objects a render layer ID pass.
In old times FP was always 1... not fun but ok.
Now my Fp was in layer 2... and I didn't know why ? because all elements was 1...
I select all scene objects and set to layer 1, ok now it is 1, but I don't know whaty I did...
Any clue ?
Thanks.
Re: Forest pack and render Layer ID pass.
Posted: Fri Jul 22, 2022 10:35 am
by paride4331
Hi HHbomb,
I'm not sure I got what you are saying, but you should assign the Object layerd ID you want, active the render layer then refresh the OctaneRender viewport.
Posted: Mon Jul 25, 2022 2:10 pm
by HHbomb
Hi Paride.
Here is a simple scene :
- a plane with Render Layer ID 1
- a teapot with ID 2
- a Forest Pack object with ID 2
I would like to have Fp object in green in the Render Layer id pass.... but no.
Posted: Tue Jul 26, 2022 3:17 pm
by paride4331
Hi HHbomb,
Is there any chance you you are using object layer color instead of Render layer ID?
Posted: Tue Jul 26, 2022 4:21 pm
by HHbomb
Hi, I use lastest octane render version now (2021.1.5_-_12.22) and if I want to change Render layer ID of forest pack objects , I need to change RL ID of Forest Pack object itself ( not its objects in Geometry tab )
Posted: Tue Jul 26, 2022 11:01 pm
by neonZorglub
HHbomb wrote:Hi, I use lastest octane render version now (2021.1.5_-_12.22) and if I want to change Render layer ID of forest pack objects , I need to change RL ID of Forest Pack object itself ( not its objects in Geometry tab )
Hi HHbomb,
That's strange, I also can't reproduce the issue.
Your scene works fine for me too; I get the FP teapots in green, layer ID 2..
Could you try this scene :
RLayerID_2_passRLid.zip
(60.76 KiB) Downloaded 117 times
I just added the Render layer ID pass, and set the teapot layer ID to 3
If you just open the Octane viewport and set the current pass to Render layer ID, you should get this:
Note that in Render settings / Support / Forest pack, the 'Use layer from FP object' is enabled, so it will use the layer ID from Forest001 (layer ID 2).
You could try to disable it, to check that it takes the ID from the referenced object as expected (Teapot001, layer ID 3)
The issue could come from some of the Octane Preference settings, but I couldn't find one that would do this..
Could you try Preferences / menu Preset : Reset Default settings ?
I tested with Forest pack 6.3.1 and 7.4.1.. what version do you use ?
Posted: Thu Jul 28, 2022 10:02 am
by HHbomb
Hi NZ,
I use OR 2021.1.5.12.22 now.
I reset default settings of Octane preferences. Now it works fine.... What was the problem is now a mystery...
Thanks.
