OctaneRender™ for Blender 2021.1.4 - 26.2 [OBSOLETE]
Posted: Thu May 12, 2022 7:46 am
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
NEW FEATURES SINCE LAST RELEASE
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 2021.1.4 here:
viewtopic.php?f=24&t=79488
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 26.2 (3.1.2)
Octane Server - Enterprise Edition - 26.2
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - 26.2 (3.1.2) Linux
Octane Server - Enterprise Edition - 26.2 Linux
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Set the Vignetting to 0 by default to match the Standalone
- Used the "new" nodes in the LiveDB as much as possible
- Fixed the modified mesh data out-of-sync issue
- Fixed the mesh data out-of-sync issue under the edit mode
- Fixed the animation render issue when the Cycles' "Persistent Data" feature is on
- Fixed the "Quick-Add" feature for the Toon Ramp textures
- Fixed "VR Scene Inspector" addon traceback
Windows
Linux
Installation:
$ OctaneServer &Blender Octane Edition - 26.2 (3.1.2) Linux
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
