Page 1 of 2
cinema 4d plugin
Posted: Fri Apr 01, 2022 4:32 pm
by A.Lopez
hello,
i'm trying to install octane plugin for cinema 4d but when I load cinema 4d i receive this error message,
thanks,
Roy
Re: cinema 4d plugin
Posted: Fri Apr 01, 2022 5:26 pm
by aoktar
Have you read and applied the install procedures? Do you have requirements of the plugin?
Posted: Fri Apr 01, 2022 5:33 pm
by A.Lopez
Yes, I do.
I've downloaded cinema 4d 25 last release to try it with octane. I've installed it. Because there is no plugins folder inside c4d path, I've created a new plugin folder on my desktop and, after opening c4d , set this folder as the plugin path. I have an octane render subscription with all the plugins included. when I run C4d with the plugin it crashes, without the plugin it works perfectly.
Roy
Posted: Fri Apr 01, 2022 5:37 pm
by A.Lopez
_BugReport.txt
(283.04 KiB) Downloaded 146 times
this is the bug report
Posted: Fri Apr 01, 2022 5:48 pm
by jayroth2020
Can you please post a screenshot of your Maxon directory, your plugins directory, and your Octane directory?
Posted: Fri Apr 01, 2022 5:54 pm
by A.Lopez
Yes, of course.
Now I've tried to move the plugin folder to the exchange plugins folder of C4d. Now it starts but I can't see octane null part.
Posted: Fri Apr 01, 2022 6:12 pm
by jayroth2020
You do not have the plugin installed correctly. You need to create a directory called "plugins", without the quote and a lower case "p" in the Maxon directory. You should then place your c4doctane directory in the plugins directory. Your c4doctane directory should look like this:
Posted: Fri Apr 01, 2022 6:39 pm
by A.Lopez
I did it but it crash.
Posted: Fri Apr 01, 2022 6:47 pm
by jayroth2020
And you did remove the other plugin from the Exchange Plugins directory, correct?
Posted: Fri Apr 01, 2022 7:04 pm
by A.Lopez
correct
