Page 1 of 2
Solo an Octane node in the viewer like in C4D
Posted: Mon Dec 20, 2021 8:20 pm
by Greg
Hey Paul - is there any way to accomplish this in the MODO version? In C4D it looks like you can (for example) solo a noise node going into (for example) bump so you just see that noise output in the Octane viewer. MODO's preview can do something similar. It would be super helpful in everybody's workflow.
C4D docs. http://www.aoktar.com/c4dmanual/index.h ... tMenu.html
Great use of it in this tutorial:
-Greg
Re: Solo an Octane node in the viewer like in C4D
Posted: Wed Dec 22, 2021 2:16 am
by face_off
Hi Greg
I love this workflow, and it's something I have been thinking about for a long time (for all my plugins). Originally I was looking at using the material preview to view individual nodes, however it is not stable with multithreaded environments, so the C4D solution is very good. Having said that, the Modo UI could present a challenge, as there is no a simple way to capture shift/alt/ctrl clicks of a schematic node. Instead, it would need to be a single button which enables "Solo mode" for the currently selected schematic node, and selected another node would then cancel "Solo mode". I will investigate more when I get a chance.
Posted: Thu Dec 23, 2021 12:02 am
by Greg
Hey Paul - I wonder if there's any sense in attempting to work more closely with the MODO devs to try and implement this (and other) features. With V-Ray gone and mPath a long ways off still, it would maybe behoove them to work with you on a tighter Octane integration.
Posted: Fri Dec 24, 2021 12:46 pm
by Dingbat
i spend quite a lot of time soloing textures manually so agree this would be a great addition for sure
would this work, for ex soloing a Multiply texture?
so in this case i'd like to see the result of multiplying 2 textures together?
Posted: Thu Dec 30, 2021 9:24 am
by face_off
There is an experimental implementation of the Solo Node function in the next release of the plugin. It this stage it will just solo a "Texture" node, but additional features can be added to the functionality over time.
Posted: Mon Jan 03, 2022 3:03 am
by Greg
Great to hear Paul, will take a look at it.
Posted: Fri Jan 06, 2023 4:08 am
by rubberchicken
Did this happen? I cannot seem to find it.
Posted: Fri Jan 06, 2023 6:35 am
by face_off
rubberchicken wrote:Did this happen? I cannot seem to find it.
Yes - it's the button below "Delete Unused Nodes" in the top left of the OctaneRender layout.
Posted: Fri Jan 06, 2023 8:19 am
by Hesekiel2517
Just tested this and It's awesome! Thank you very much, did not know it was there too
Posted: Sat Jan 07, 2023 5:13 am
by rubberchicken
That's great thanks Paul. Could not locate this in the docs either.
