OctaneRender for Maya 2020.2.5-19.17 [STABLE]
Posted: Fri Aug 13, 2021 2:49 am
by JimStar
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya® Version 2020.2
Maya® Version Requirements
This release will work with Maya® Versions 2017, 2018, 2019 and 2020 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 2020.2.5
Changes since version 19.16:
  • Integrated the 2020.2.5 rendering engine.
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
OctaneRender for Maya Enterprise [MacOS]
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
OctaneRender for Maya Studio [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
OctaneRender for Maya DEMO [MacOS]
Re: OctaneRender for Maya 2020.2.5-19.17 [STABLE]
Posted: Fri Aug 20, 2021 2:47 pm
by glimpse
Good day, Jim.
Any news about install to more recent Maya version?
Posted: Thu Sep 23, 2021 9:00 am
by zurakan
hello
Can you put tonemap hdr option back?
or i can find some where this option ?
thank so much
Posted: Thu Sep 23, 2021 1:25 pm
by zurakan
When i set OCIO i can not use batch render.
Posted: Thu Sep 23, 2021 10:46 pm
by JimStar
zurakan wrote:hello
thank so much
It is here:
Posted: Fri Sep 24, 2021 5:35 am
by zurakan
https://drive.google.com/file/d/1x5VtfK ... sp=sharing
Gamma in octaneImager is not effect to render,
i try to use Ocio but 2020.2.5 i can not use batch render
now i use 20.20.2.1 and 19.17 it can .
but some time image from render , same setting (Ocio),But have render layer and no renderlayer (the blueberry no renderlayer )
Posted: Sun Sep 26, 2021 9:47 pm
by BK
zurakan wrote:https://drive.google.com/file/d/1x5VtfK ... sp=sharing
Hi Zurakan,
Thank you for the video!!
Could you please check if there is an OCIO config file loaded under the RenderSettings>Octane tab>OCIO rollout?
Usually, if there is an OCIO file loaded then we disable the Tone Map settings internally.
- Please make sure to keep the OCIO file path empty
- Save the file and Re-open and see if it fixes the issue.
- By the way, how are you animating the blueberry? please make sure to set the animation as *Force Load* on the Animator Data!
Please share a sample file for us to test on our machines if the issue still exists?
cheers
Posted: Fri Oct 01, 2021 7:42 am
by zurakan
https://drive.google.com/drive/folders/ ... sp=sharing
i already test thst you told , not work
Posted: Mon Oct 04, 2021 2:09 am
by BK
zurakan wrote:https://drive.google.com/drive/folders/ ... sp=sharing
Hi Zurakan,
Thank you so much for attaching the video and the scene.
Octane Imager's Tone Mapping will not work along with the OCIO config.
Your scene worked fine on our test.
The Gamma would also work once you unload the OCIO file from the RenderSetings>Octane tab>OCIO rollout
Please refer to this link below for the correct OCIO workflow:
viewtopic.php?p=403379#p403379
cheers
