Post Processing Not Working
Posted: Wed Jul 07, 2021 12:24 pm
by mikegem
Preview or final Post processing not working. If I enable just the post processing pass I can see the effects, but when I go to combined there is no effect. If I use the compositor and combine post layer with image I can see the effect in final render.
Re: Post Processing Not Working
Posted: Wed Jul 07, 2021 9:54 pm
by linograndiotoy
You should disable Post Process in the Render Passes. If you keep it on, Post Process will be exported in a separate pass (you don't want Post Process to be also in the "main" pass in that case).
Posted: Thu Jul 08, 2021 2:30 pm
by mikegem
WELL ALLLLLLLLLRIGHT!!! Thank You!! :D :D
Posted: Sat Jul 10, 2021 8:38 am
by linograndiotoy
Sure!
