HQueue hquser crashing
Posted: Wed Nov 25, 2020 4:34 pm
Hey,
Trying to figure out why octane crashes when launched via hqueue, hython or hscript as the "hquser" username.
when launched as the main user, "ptunstall", I don't have this issue when rendering from both hython and hscript.
I've added hquser to the "wheel" group as this is the way to give users SUDO privilege's in centos.
I've also chmod -R 777 /opt/Octane* so there shouldn't be any permission issues with octanes install path.
Do you know why this might be happening?
[hquser@weeWhammy hfs18.0]$ cd /opt/hfs18.0 && source houdini_setup
The Houdini 18.0.597 environment has been initialized.
[hquser@weeWhammy hfs18.0]$ hscript
[Octane] Octane Render for Houdini. Build 2020.1.5.3 (Build date: Nov 5 2020 20:37:21)
[Octane] Octane API: 2020.1.5
[Octane] HDK API: 18.0.597
[Octane] Houdini host version: 18.0.597
[Octane] Initializing Octane API
14938 ThreadId=0x7fa6aebff700: Fatal error: Segmentation fault
-- TRACEBACK BEGIN --
Traceback from hbatch 18.0.597 (Compiled on linux-x86_64-gcc6.3):
stackTrace() <libHoudiniUT.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo_t*, void*) <libHoudiniUT.so>
_L_unlock_13 <libpthread.so.0>
Octane::maxHosts(Octane::NetInterfaceInfo const&) <liboctane.so>
Octane::runFeaturesCheck() <liboctane.so>
Octane::ApiProjectWorkspace::getNodeGraphEditors() <liboctane.so>
Octane::ApiFileChooser::results() const <liboctane.so>
start_thread <libpthread.so.0>
__clone <libc.so.6>
-- TRACEBACK END --
14938: Fatal error: Segmentation fault (sent by pid 14938)
__pthread_cond_wait <libpthread.so.0>
Octane::apiMode_Shared_start(char const*, bool, char const**, char* (*)(void*), void*, bool) <liboctane.so>
HOctane_initAPI(bool) <Houdini_Octane_18.0.597.so>
ROP_Octane::getTemplates() <Houdini_Octane_18.0.597.so>
ROP_Octane::getTemplatePair() <Houdini_Octane_18.0.597.so>
newDriverOperator <Houdini_Octane_18.0.597.so>
UT_DSO::run(char const*, void*, bool) <libHoudiniUT.so>
OP_OperatorTable::runDSOInstall() <libHoudiniPRM.so>
OP_Network::getOperatorTable(UT_StringRef const&, char const*) <libHoudiniPRM.so>
MGR_Node::buildRopTable(char const*) <libHoudiniOPZ.so>
MGR_Node::initTable(MGR_MANAGER_TYPE) <libHoudiniOPZ.so>
MOT_Director::MOT_Director(UT_StringHolder const&, bool, bool) <libHoudiniOPZ.so>
_init <hbatch-bin>
__libc_start_main <libc.so.6>
_init <hbatch-bin>
-- TRACEBACK END --
