match AC render resolution
Posted: Fri Oct 09, 2020 8:50 am
by Dingbat
is there a simple way to do this? I've had a look through the settings but AFAICT you have to manually set the resolution in the camera 'Film' settings.
Re: match AC render resolution
Posted: Sat Oct 10, 2020 10:39 am
by face_off
Hi - if you do a Photorender using the OctaneRender renderer, the resolution should automatically match.
Posted: Wed Oct 14, 2020 8:26 am
by Dingbat
thanks for the reply.
how about with the pop up render window? i usually use this window while working - should i be using the main render window?
Posted: Sun Oct 18, 2020 11:26 pm
by face_off
Hi
The OctaneRender Viewport (ie. NOT the Photorendered) cannot access the Photorenderer setting (like resolution), since the ArchiCAD SDK isolates the Photorenderer functions from the rest of the API. So I don't think this would be possible.
Posted: Thu Oct 22, 2020 4:30 pm
by Dingbat
is there a way to select which render pass to view with the Photorender viewport (F9 render)?
using the Octane viewport i can't quickly copy paste the rendered images and need to save/import.
using the AC viewport i can copy/paste the renders but looks like i can't select render pass?
Posted: Thu Oct 22, 2020 10:23 pm
by face_off
You could try enabling "Scene Refresh on View Change" in the plugin settings (hover the mouse for the tooltip), and then opening the Viewport and select a render pass then open the Photorenderer.
Posted: Mon Oct 26, 2020 10:25 am
by Dingbat
thanks. it's not the most fluid workflow but it works OK.
@ face_off, sorry to post this here but have you had a chance to look at the Direct Light issue i posted? have you been able to verify or is this a problem my end?
viewtopic.php?f=56&t=76088
Posted: Mon Oct 26, 2020 11:57 pm
by face_off
Dingbat wrote:thanks. it's not the most fluid workflow but it works OK.
I just responded in that thread.
