OctaneRender™ for Blender 2020.1.4 - 21.13 [OBSOLETE]
Posted: Sun Aug 30, 2020 9:04 pm
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
NEW FEATURES SINCE LAST RELEASE
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 2020.1.4 here:
viewtopic.php?f=24&t=75421
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 21.13 (2.83.5)
Octane Server - Enterprise Edition - 2.83.5
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
OSX
DOWNLOAD
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Upgraded to Blender 2.83.5
- Enhanced Orbx Preview feature
- Added "External Alembic" Orbx Preview Type to support animated Orbx preview
- Fixed Orbx Preview issue when dealing with relative file paths
- Fixed some other issues in the Orbx Preview
- Enabled Cycles OptiX support
- Fixed hair motion blur when rendering the object with varied hair number
- Fixed the rendering issue when using the linked collections with the same name
- Fixed octane sphere primitive attributes issue when dealing with alembic sequence
- Disabled the "Prefer tonemap" option during rendering(it cannot be changed after render setup)
- Fixed the painted texture update issue
- Fixed the reroute node issue
- Fixed the typos in the Specular Material
Windows
Linux
Installation:
$ OctaneServer &Blender Octane Edition - 21.13 (2.83.5)
OSX
DOWNLOAD
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
