Page 1 of 2
particle hair
Posted: Thu May 21, 2020 6:48 pm
by protovu
I have seen some amazing Octane hair, and I am trying to do a little hair for a client project. Nothing fancy, but having a real struggle. Preview and Render are way off.
Looking for guidance on how to have Preview Render Hair match Render Hair.
Please see attached.
Any help appreciated.
Re: particle hair
Posted: Thu May 21, 2020 7:19 pm
by linograndiotoy
protovu wrote:I have seen some amazing Octane hair, and I am trying to do a little hair for a client project. Nothing fancy, but having a real struggle. Preview and Render are way off.
Your scene works perfectly here. Out of curiosity, how much memory do you have on your GPU(s)?
Re: particle hair
Posted: Thu May 21, 2020 7:37 pm
by protovu
Thanks, Lino.
Can you show me an image of your Render and Preview?
I am using 2 RTX 2080 supers.
Re: particle hair
Posted: Thu May 21, 2020 8:47 pm
by grimm
I'm getting the same results that you are...
Viewport:
Rendered:
Version 21.7
Re: particle hair
Posted: Thu May 21, 2020 9:01 pm
by protovu
Thank you for showing me that! Nothing worse than thinking there is something wrong with my setup.
The hair we are using here came with a model. I did not make it.
I know next to nothing about particle hair, so a few quick questions, if you can indulge me:
Is the workflow to redo the hair Blender based , then Octane adjusted?
Or, should I use an Octane-Blender specific hair tutorial, so I do not end up in the same dillema?
Your advice appreciated,
Rick
Re: particle hair
Posted: Thu May 21, 2020 9:11 pm
by grimm
Yes, you would create a particle hair system in Blender and then adjust it with the plugin to render. I haven't had any problems rendering Blender hair in Octane, although I haven't done it very much. :)
Jason
Re: particle hair
Posted: Thu May 21, 2020 9:27 pm
by protovu
Thank you, Jason.
I thought I saw some amazing Octane hair on the Blender Octane Render Forum , but now I cannot find it.....even in the archives. (insert sad imogee face here)
If I discover anything not obvious, I will share.
Rick
Re: particle hair
Posted: Thu May 21, 2020 10:46 pm
by J.C
You must enable "Show emitter " in particle render settings.
To adjust the look of the hair play with Root and Tip thickness in Octane hair settings which is located below hair/particle settings.
Re: particle hair
Posted: Thu May 21, 2020 11:07 pm
by protovu
JC to the rescue again!
1. Again, Octane owes you a salary.
2. I am moving into your basement so I can get all the answers I need.
Re: particle hair
Posted: Thu May 21, 2020 11:19 pm
by protovu
OK....much better, but I am still working in the dark. That is , Preview does not match Render.
It is supposed to match, correct?
Any advice appreciated, thank you.
