slow object scattering
Posted: Tue May 19, 2020 9:20 pm
by dobe
Hi octane user,
i have try to do a grass field with megascans 3d plants in octane and Blender 2.8.... but somehow it's very slow.
I compared it to e-cycles and graswald. both are much faster even if the result is not necessarily the best.
i have used the "scatter plugin" from blendermarket: https://blendermarket.com/products/scatter
3:10min to 15:00min is a huge diffrent
Is there a solution to speed up the rendertime in octane?
Re: slow object scattering
Posted: Wed May 20, 2020 2:00 pm
by linograndiotoy
There several ways to speed up render time.
Would you mind sharing your scene and/or your setting so we can take a look?
I've rendered this in less than 1 minute and 6 seconds (500 samples, no denoiser used - 2 RTX 2080 Ti cards):
Posted: Wed May 20, 2020 3:25 pm
by grimm
Yes, if you could share your scene, I have both Graswald and the Scatter plugin. It would also be nice to know what your hardware is, GPU and driver version.
Jason
Posted: Thu May 21, 2020 8:09 am
by J.C
Scattered objects with alpha transparency can really slow down Octane renderings. The only cure for this at the moment i know is to enable RTX.
eg.
a scene rendered with 256 samples, scattered grass with alpha transparency takes:
RTX OFF:
42 sec
RTX OFF and alpha shadow off
36 sec
RTX ON alpha shadow off
10 sec
RTX ON
13 sec
