OctaneRender 2020.1 for Houdini Production build 2020.1.0.8
Posted: Tue May 12, 2020 8:54 pm
This is a production release of the OctaneRenderâ„¢ 2020.1 for Houdiniâ„¢ plugin compiled with the Octane 2020.1 core. This 2020.1.0.8 release is available for the Houdini 16.5/17.0/17.5/18.0 latest production builds on Windows x64, Linux gcc6.3.1 and MacOS 10.12.
To use Octane 2020.1, you need to have a Studio or Enterprise subscription license. We recommend you to update your NVIDIA driver to at least 435.80 for Windows or 435.12 for Linux.
New features
To learn more about the new features and improvements of OctaneRender 2020.1, please check out the 2020.1 release post, but this is a quick list of the main new features that have been added.
Release 2020.1.0.8 Enterprise subscription license
https://render.otoy.com/customerdownloa ... rprise.zip
Release 2020.1.0.8 Studio subscription license
https://render.otoy.com/customerdownloa ... studio.zip
Release 2020.1.0.8 Demo license
https://render.otoy.com/plugindownloads ... 4_demo.zip
https://render.otoy.com/plugindownloads ... x_demo.zip
https://render.otoy.com/plugindownloads ... X_demo.zip
Standalone 2020.1 version for the network rendering nodes
viewtopic.php?f=24&t=74586
Release Notes
RELEASE 2020.1.0.8
* PLUGIN FEATURES AND FIXES:
- Fixed a crash on Linux while rendering to disk.
- Addressed the Render Target SHOP HDA deprecated parameters.
- Fixed a warning in the Spectron light HDA.
- Removed the Houdini Indie rendering and scene exporting restrictions.
- New option in the ROP node, Output tab, to use short names without spaces for the EXR layers.
- New plugin build for H18.0.460
RELEASE 2020.1.0.7
* OCTANE 2020.1 FEATURES AND BUGS FIXED:
- Fixed CUDA error on the slave when RTX was enabled and the scene used dirt or accurate rounded edges.
- Fixed CUDA error happening when using AI light in scenes while enabling RTX and mixing RTX and non-RTX geometry.
- Fixed opacity issue with metallic material or with universal material with metallic set to 1.0.
- Fixed issue causing the network daemon to give up starting the slave at start-up on slow machines.
- Fixed application crash importing LiveDB materials that would include material layer input linker nodes.
- Fixed camera target picker for mesh instances handled by RTX.
- Reduced required runtime memory per sample.
- Removed "(experimental)" from RTX flag text in the device settings.
Happy rendering,
Your OTOY Team
New features
- New option to enable the RTX improvements.
- Spectron Area and Sphere light types.
- Particle and Curves Point Attributes.
- New Hosek-Wilkie Spectral Sky Model.
- Improvements to Round Edges artist control.
- SSS Improvements and Random Walk SSS.
- Spectral Hair Material.
- ACES: new workflow and Image Container File Layout
- Volume Step % and Shadow Step %
- Volume Sample Position Displacement
- New Universal Dirt System
Release Notes
RELEASE 2020.1.0.8
RELEASE 2020.1.0.7
Happy rendering,
Your OTOY Team
