Octane 2020 Linux Crash
Posted: Fri May 08, 2020 4:27 pm
Hello,
Houdini crashes whenever I click the "Render to Disk"-Button in Octane ROP. This is the case with File Output as well as the "Render to MPlay" option.
However, IPR (using MPlay) works fine. In fact, when IPR was started, it works when "Render to MPlay" is checked. And, as expected, it then renders to MPlay.
Currently, I am using Houdini Indie 18.0.416, but the same problem occurs on 17.5.460.
With plugin version 2019.1.5.0, this problem does not appear. Only since 2020.
I would attach the Octane log, but it isn't even created.
Console output after the crash is:
Here is the crash log houdini generated:
System Information:
OS: Arch Linux
CPU: Ryzen 9 3900X
GPU: RTX2080super
RAM: 64GB
EDIT: I have attached a test scene which crashes as explained.
1261116: Fatal error: Segmentation fault (sent by pid 192)Code: Select all
Crash report from username; Houdini FX Version 18.0.416 [linux-x86_64-gcc6.3]
Uptime 538 seconds
Fri May 8 18:22:31 2020
Caught signal 11
Traceback from 1261116 ThreadId=0x7fb2b89e7c80
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo_t*, void*) <libHoudiniUT.so>
__funlockfile <libpthread.so.0>
Octane::VdbInfo::sampler(unsigned int, bool) <liboctane.so>
Octane::ApiNode::connectedNode(Octane::PinId) const <liboctane.so>
HOctane_cleanOctaneSceneNodeGraph(bool) <Houdini_Octane_18.0.416.so>
HOctane_cleanScene(bool) <Houdini_Octane_18.0.416.so>
HOctane_IPR_stop() <Houdini_Octane_18.0.416.so>
HOctane_IPR_closeMplay() <Houdini_Octane_18.0.416.so>
ROP_Octane::startRender(int, double, double) <Houdini_Octane_18.0.416.so>
ROP_Node::executeSingle(double, ROP_Verbose*, SOHO_IPRList*, ROP_SohoOutput*, bool) <libHoudiniOP4.so>
ROP_RenderItem::render(ROP_Verbose*, int, int) const <libHoudiniOP4.so>
ROP_RenderManager::renderOrder(ROP_RenderList const&, ROP_Verbose*) <libHoudiniOP4.so>
ROP_RenderManager::render(ROP_Node*, double, double, double, bool, bool, bool, bool, bool, ROP_Verbose*) <libHoudiniOP4.so>
ROP_Node::renderCommand(ROP_RenderCmdParms&) <libHoudiniOP4.so>
ROP_Node::doRenderCommand(CMD_Args&, OP_Node*, bool) <libHoudiniOP4.so>
ROP_Node::cmdRender(CMD_Args&) <libHoudiniOP4.so>
CMD_Manager::runCommand(char*) <libHoudiniPRM.so>
CMD_Manager::internalExecute(char const*) <libHoudiniPRM.so>
CMD_Manager::processInput(CMD_Source*, char const*) <libHoudiniPRM.so>
CMD_Manager::internalSendInput(char const*, bool) <libHoudiniPRM.so>
CMD_Manager::sendInputNoLock(char const*, bool) <libHoudiniPRM.so>
CMD_Manager::executeNoLock(char const*, bool, std::ostream*, std::ostream*, bool, bool) <libHoudiniPRM.so>
void UT_TaskArena::callbackConst<CMD_Manager::execute(char const*, bool, std::ostream*, std::ostream*, bool, bool)::{lambda()#1}>(void const*) <libHoudiniPRM.so>
tbb::interface7::internal::task_arena_base::internal_execute(tbb::interface7::internal::delegate_base&) const (arena.cpp:943)
TBBPROXY_TaskArenaExecute <libTBBPROXY.so>
CMD_Manager::execute(char const*, bool, std::ostream*, std::ostream*, bool, bool) <libHoudiniPRM.so>
OPUI_RenderDialog::launch(ROP_Node*, ROP_RenderMode) <libHoudiniAPPS2.so>
ROP_Node::doRenderCback(void*, int, double, PRM_Template const*) <libHoudiniOP4.so>
OP_Node::triggerParmCallback(PRM_Parm*, double, int, void*, UT_Options const*) <libHoudiniPRM.so>
PSI2_DialogPRM::performParmCallback(PRM_Parm*, int) <libHoudiniAPPS2.so>
OPUI_DialogPRM2::performParmCallback(PRM_Parm*, int) <libHoudiniAPPS2.so>
PSI2_Dialog::triggerParmCallback(OP_Node*&, PRM_Parm*&, int, bool&) <libHoudiniAPPS2.so>
PSI2_Dialog::parmChanged(int, UI_Reason, int, bool) <libHoudiniAPPS2.so>
PSI2_Vector::changed(UI_Object*, UI_Reason, UI_DeviceEvent*) <libHoudiniAPPS2.so>
UI_Button::endSelect(UI_Event*) <libHoudiniUI.so>
SI_ParmButton::endSelect(UI_Event*) <libHoudiniUI.so>
UI_Window::handleEvent(UI_Event*) <libHoudiniUI.so>
UI_Queue::processNextEvent() <libHoudiniUI.so>
UI_Queue::drain() <libHoudiniUI.so>
UI_Queue::eventLoop() <libHoudiniUI.so>
main <libHoudiniUI.so>
__libc_start_main <libc.so.6>
main <houdini-bin>
OS: Arch Linux
CPU: Ryzen 9 3900X
GPU: RTX2080super
RAM: 64GB
