Memory maxes out
Posted: Mon Jan 20, 2020 6:32 pm
by hgarrou
Rendering the side of a mountain. Model is about 700MB 6 x 16K textures on simple Octane Diffuse Material.
All Geometry and Geometry shape nodes have force load disabled. There's only 6 meshes in the scene and one camera, one env map (2K) and one Octane Light.
Notice How my memory mounts over time. I can only reder 6 frames without have to stop the render and restart.
Is this a memory leak?
When I batch render, the memory level drops when I stop the render.
When I Render Sequence the memory level never drops and you have to restart Maya to render more than 6 frames.
Re: Memory maxes out
Posted: Mon Jan 20, 2020 6:57 pm
by JimStar
The plugin does not manage the GPU memory load - this is done by Octane rendering engine. The plugin just builds the Octane's native nodegraph in the CPU memory, and then just switches the frames. And this is the Octane rendering engine that is loading/unloading the frames' data to/from GPU memory...
But I can check just in case to be sure it's not some plugin-side issue, if you give me this scene you are testing with.
Do you use the "frames to pre-cache" in the plugin or you have it set to "0"?..
Posted: Mon Jan 20, 2020 7:28 pm
by hgarrou
Thanks for the quick response.
Frames to precache is set to 0.
here's a scene for testing with a set of 8K textures
https://drive.google.com/file/d/1UcJsEy ... sp=sharing
Oh yeah, I'm using 2020.1 XB2
Maya 2020
on a PC
Posted: Fri Jan 24, 2020 3:59 pm
by hgarrou
I do see a line item in the list of fixes in xb3 that addresses growing memory reports. I think once there's a plug-in for xb3 I'll test it and see if this problem is solved. Thanks for all your help and attention.
Posted: Sun Feb 02, 2020 9:31 pm
by JimStar
Yes as I can see this is a rendering engine issue. I've told about it to the engine team, they said me they will have a look into this when they have time.
So if the XB3 does not fix this for you (going to release it soon) - then you'll need to wait before this gets fixed by the rendering engine team (and probably be reminding about it in the standalone section).
As a workaround for today - you can try to switch on the "out of core" functionality and see if this would work any better for you...
Posted: Mon Feb 03, 2020 5:55 am
by hgarrou
Thanks, Jim. I'll try that.
Posted: Wed Feb 05, 2020 6:40 pm
by hgarrou
XB3 all fixed. GPU memory usage is now level across render of multiple frames.
The first low readiing is with render sequence. The second higher reading is using batch render.
Thanks for all your attention on this Jim.
