Page 1 of 2
c4d hangs at startup ( R21 with every OC 2019 version)
Posted: Tue Nov 12, 2019 4:58 pm
by useruser
hello,
meanwhile this is the third version of oc 2019 enterprise which causes a hang up at startup (plugin initializing)
this issue only appears with c4d R21. R20 with oc 2019 works without any problem ( same workstation)
deleting the "otoy_credentials" does not help.
the logfile shows nothing:
[2019-11-12 17:51:33][1] Register OctaneLive
thanks a lot in advance!
Re: c4d hangs at startup ( R21 with every OC 2019 version)
Posted: Tue Nov 12, 2019 7:42 pm
by aoktar
It may be due to blocking octane plugin from firewall or antrivirus software.
Posted: Wed Nov 13, 2019 3:43 pm
by useruser
everthing is disabled. but the issue is still there
thanks in advance
Posted: Wed Nov 13, 2019 4:07 pm
by aoktar
1-be sure that everything installed correctly and using at least 21.022 not older version.
Posted: Tue Nov 19, 2019 12:31 pm
by useruser
hi ahmet
nothing works. u updated everything ( C4d R21.026) disabled the firewall completely but octane hangs at startup
i also tried to add a specific firewall-rule for R21 (incomming and outcomming tasks) but nothing helps
i also deleted every other plugin
i installed the oc-standalone and the slave-daemon, both are working on the workstation without any trouble.
C4d R20 works also without any problem
thanks in advance! :)
Posted: Tue Nov 19, 2019 12:39 pm
by aoktar
What's install path for plugin?
Posted: Tue Nov 19, 2019 7:41 pm
by useruser
C:\Program Files\MAXON\Cinema 4D R20\plugins\c4doctane
Posted: Tue Nov 19, 2019 8:46 pm
by aoktar
Why do you show R20 version? You say R21 is not working..
Posted: Fri Nov 22, 2019 1:06 am
by useruser
sorry
that was the wrong screenshot
this is the right one:
the oc-plugin is installed in the first directory. but no matter which one i use: the result is all the same.
hangs on startup
Posted: Mon Nov 25, 2019 8:31 am
by bepeg4d
Please, change the name of the folder from Plugins to plugins, and install only a copy of c4doctane folder, removing in it the unnecessary .cdl64/.xdl64 files not related to R21.
ciao Beppe
