Need Help
Posted: Wed Sep 25, 2019 11:21 pm
by arlind
Hello!
I'm using octane with cinema 4d but I am experiencing a problem.
When I render with the live viewer (capture1) for testing material I get that render
but when I render it in picture viewer (capture2) it doesn't render a portion of the material (capture3) it doesn't render the emission tab because of the backlight effect is c4d shader and this type of shader doesn't render?
It also shows me this log:
I started the log very late of doing this and I don't know which part says about this (could not paste the whole log here though).
PS: Did some different render tests with different options in the Kernel but still the same results.
Started logging on 25.09.19 18:28:34
OctaneRender Studio 4.02.1 (4020100)
Can't write int to static pin 'keepInstancePower' (P_KEEP_INSTANCE_POWER, type PT_BOOL) of node 'Texture emission' (NT_EMIS_TEXTURE, 0000026CDDB5F670)
Can't connect node 'Scattering' (NT_MED_SCATTERING, 0000026CDE77FF20) to static pin 'transmission' (P_TRANSMISSION, type PT_TEXTURE) of node 'OctDiffuse' (NT_MAT_DIFFUSE, 0000027633BAF880)
Re: Need Help
Posted: Fri Sep 27, 2019 7:58 am
by bepeg4d
you have posted in the wrong section, please, next time, use the c4doctane section instead:
viewforum.php?f=30
If you cannot post in this section, please write to help at otoy.com, sharing your Otoy UserName, thanks.
About your issue, please, avoid to use c4d shaders, and use only Octane nodes, for better results and stability.
In particular, use only octane nodes especially with emission, and the c4d Layer shader is not supported, and cangive great instability issues.
ciao Beppe
