OctaneRender™ for Blender 2019.1 - 18.4 [OBSOLETE]
Posted: Mon Sep 16, 2019 6:18 am
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
NEW FEATURES SINCE LAST RELEASE
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 2019.1 here:
viewtopic.php?f=24&t=72584
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 18.4 (2.79)
Octane Server - Enterprise Edition - 18.4
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - Enterprise Edition - v18.4 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - Enterprise Edition - v18.4 OSX ZIP
REGULAR LICENSES (FOR V4 USERS):
The download links, provided in this post, are intended for OctaneRender Enterprise License Holders (which requires OctaneRender All-Access). For users still using OctaneRender 4, it is possible to access this Test Release thanks to our specially-made "Regular" versions. The links for these "Regular" builds can also be found in the links below:
Windows
Octane Server (Regular Version)
Linux
Blender Octane - Regular Version - v18.4 Linux
OSX
Blender Octane - Regular Version - v18.4 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Update SDK to 2019.1
- Fixes in baking layer settings
- Complete the baking layer transform setting under "Property-Object-Baking Layer", which will be the correct place for changing baking transform
- Remove the baking layer setting under "Property-Render Layer-Baking Layer"
- Use "Property-Camera-Baking-Baking group ID" to change the baking group in the scenes
- Fixes in kernel settings
- Fix wrong gray ui
- Hide unnecessary options in different kernels
- Remove deprecated gi modes
- Fixes in VDB render
- Fix VDB black box issue
- Fix VDB update issue under preview render
- Fix OSL update issue under preview render
- Fix group layer material LiveDB crash issue
- Fix warning about "use_adaptive_subdivision"
Windows
Linux
Installation:
$ OctaneServer &Blender Octane Edition - Enterprise Edition - v18.4 Linux
OSX
Installation:
DOWNLOAD
Windows
Linux
OSX
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
