Displace bug
Posted: Thu Sep 12, 2019 6:44 pm
There is a bug in the displacement map:
I need to put a texture in a precise place of more big surface. So I build the UV to place exactly the texture (Image 1).
I use Black Border Mode, so the image isn't tailed on all the surface, and it is OK... if used in diffuse channel (Image 2).
But if I use the same texture in displace, it becomes tailed, as Warp Border Mode, not as Black (or white). Only Warp. (Image 3).
There is a solution of it or it is a bug?
Thank you
Gianluca
Thank you
Gianluca
