Camera Motion Blur + Perspective Correction = doesn't work
Posted: Sun Aug 18, 2019 10:06 pm
by desire
Hello!
This issue is old, but CamMB+PerspCorr still doesn't work.
Currently tested on latest stable V4.05-R2
Why? I've found a topic 2 years old with words "I'll look", but nothing changed
Should I post it over Octane engine thread?
forum message
forum message
Re: Camera Motion Blur + Perspective Correction = doesn't work
Posted: Mon Aug 19, 2019 6:18 am
by aoktar
Yes it's about capabilities of renderer. Not about plugin. I don't think it's a bug, just an unsupported feature.
Posted: Mon Aug 19, 2019 6:42 am
by bepeg4d
try with the sub-frame trick:
ciao Beppe
Posted: Mon Aug 19, 2019 12:18 pm
by desire
bepeg4d wrote:Hi,
ciao Beppe
thank you for reply, but the trick does not effect on Camera MB + PerspCorr. I had just one result - or corrected perspective or Camera MB, not both unfortunately
Posted: Mon Aug 19, 2019 12:29 pm
by desire
aoktar wrote:Yes it's about capabilities of renderer. Not about plugin. I don't think it's a bug, just an unsupported feature.
Thank you for your reply.
So, since that time, may be it was real to speak with Octacore enginers to emplement this feature to render capabilities?
I use just c4d plugin, not standalone, not any other... Why I need to know if it a plugin or a core restriction?
I'm trying to speak gentle, with respect, but can't even find right words ))
Very necessary combo (CamMB + PerspCorr) for architects and so on... I think not only for c4d users, and for other apps.
Not once the question was born on the forum. But over years still doesn't work ))
upd.: if you know at what thread this topic would be actual, please, move to that.
Posted: Mon Aug 19, 2019 2:43 pm
by bepeg4d
the best way to ask a new feature in SDK is to write here:
https://render.otoy.com/requests/?qa=ask
Alternatively, you could set the pitch rotation to 0, and use the Lens Shift option, instead of the Perspective correction.
ciao Beppe
Posted: Tue Aug 20, 2019 5:14 am
by desire
bepeg4d wrote:Hi,
ciao Beppe
Thank you for reply
I know and use time to time option you mentioned.
It works well on a dolly shots or simple cam animation
Posted: Sun Aug 25, 2019 10:31 pm
by roeland
the Octane render core has no such limitation, you can use motion blur and perspective correction at the same time.
Do you see the same limitation in Octane Standalone if loading a file exported from the plug-in?
Posted: Tue Oct 06, 2020 7:00 am
by jeremyshin
Still not working for me, with latest build.
When will it be possible ? Please.
