backplate / reflections broken
Posted: Wed Jul 10, 2019 5:57 am
Daylight backplate/reflections/refractions doesn't work. Version 4.05 - 6.19.
I have three daylights. One set to main & texture for lighting. One set to visible & texture with reflections checked. One set to visible & texture with backplate checked. The backplate doesn't work unless I turn off the light that has reflections checked. What is the point of this if you can't have unique maps for each entry?
The current implementation, of needing multiple daylights with trojan horse check boxes and textures, has always been a design travesty.
Also, the daylights in Max are still labeled as 'Object' under the object type.
