visibility toggle NOT possible...please help
Posted: Fri Jun 28, 2019 3:38 pm
by protovu
Akk,,
This continues to frustrate:
Cannot toggle visibility off during an animation.
Even removing an object from the camera view is not working. The object still renders!!!!
With the attached file, I have included 3 rendered frames of a single object.
Starting at frame 5, the object is visible and within the camera view.
In frame 6 and 7 Visibility is toggled off in all available toggles, both Blender and Octane, AND, the object is moved out of view.
but it still renders!!!
The only way I can not have the object render is to start the render on frame 6.
This is no way to animate.
Please help.
This has been going on for quite a while.
I am happy to upgrade if that will fix the problem. This has been going on since I started with Blender Octane, 2018.
Win10pro
dual xeon
32g
4 GPU- titan x2, 1080, 970
nvidia 4.17.17
StandAlone V4 / Blender_Octane_Edition_4.02.1_16.3.3stable
Re: visibility toggle NOT possible...please help
Posted: Fri Jun 28, 2019 11:01 pm
by J.C
Your file works fine. Object is not rendered when the Octane visibility is turned off or when object is moved out of camera view.
Posted: Fri Jun 28, 2019 11:03 pm
by J.C
Have you tried in latest version 17.9?
Posted: Fri Jun 28, 2019 11:10 pm
by protovu
Hi JC,
Thank you for the quick look and response. Much appreciated.
I have been too busy to update, but will this weekend.
To confirm: you rendered the file as an animation, starting with the object visible correct? As opposed to rendering still images one at a time.
Thank you,
Rick
Posted: Sat Jun 29, 2019 10:55 am
by ChrisH
Hi!
It seems to work fine here (17.9).
Also disable the location animation and the "Render visibility" worked fine on it's own!
Posted: Sat Jun 29, 2019 2:09 pm
by protovu
I upgraded and will try now.
And the winner is........Yay! Worked as desired.
Thank you , JC and Chris!
Posted: Sat Jun 29, 2019 3:59 pm
by J.C
protovu wrote:Hi JC,
Thank you,
Rick
Yes, I started from frame 0
