Baking Issue -- Not working with imported object
Posted: Wed Jun 26, 2019 3:20 am
by likeshesaid
Hello!
Two questions.
First:
Why isn't the baking camera picking up this heart object? It works with the sphere. The camera just comes up completely black.
Second:
When using the sphere, how do I get the Octane Camera to align perfectly with the UV as it is when you look at it in UV edit? I really hope I don't have to manually align (with the guess-and-check method) every time...
Here's my scene file so you can take a look: https://www.dropbox.com/s/7tmnr4eypigz8 ... s.c4d?dl=0
I'm running Octane 4.04 and R20 (but this should be backwards compatible for testing)
Thanks so much!
Nicole
Re: Baking Issue -- Not working with imported object
Posted: Wed Jun 26, 2019 3:09 pm
by bepeg4d
Hi Nicole,
if you switch the Kernel to Info Channel/Geometric Normals, you can see that the heart normals are inverted, so you are currently baking the inside, having a black result:
You need to firstly reverse the normals:
Please, only use Octane materials, hide the sphere, set the Film Aspect at 1:1 to have a square result, assign a different Baking ID to each object tag, and change the Baking ID in the Camera node accordingly:
love_heart-low_res_b.c4d.zip
(69.83 KiB) Downloaded 130 times
ciao Beppe
Posted: Wed Jun 26, 2019 3:32 pm
by aoktar
Strangely that reversing the normals solved that! Didn't expect this behavior.
Posted: Wed Jun 26, 2019 8:05 pm
by likeshesaid
Thank you Beppe! Amazing.
