OctaneRender™ for Blender 2019.1.XB2 - 18.0 [OBSOLETE]
Posted: Wed Jun 26, 2019 12:28 am
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Perpetual License Holders.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
NEW FEATURES SINCE LAST RELEASE
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 2019.1.XB2 here:
viewtopic.php?f=33&t=71538
The installation consists from two parts:
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 18.0 (2.79)
Octane Server - 18.0
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v18.0 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v18.0 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Refactor object layer data: now they are moved from mesh data panel to object data panel
- Update sdk to 2019.1.XB2
- New 2019 features(except the built-in script nodes(mix displacement, universal camera...))
- Add AI Up-Sampler
- Add "affect roughness" option in kernels
- Add "max subdivision level" option in kernels
- Add round edges
- Add shadow catcher material, layered material, and composite material
- Add group layer, diffuse layer, metallic layer, sheen layer, and specular layer
- Add vertex displacement
- Add "Cutoff" option in postprocess
- Fix particle motion blur issue
- Fix global mesh smooth issue
- Disable octane export passes unless cryptomatte is on
- Make it more robust when handling local db path
Windows
Linux
Installation:
$ OctaneServer &Blender Octane Edition - v18.0 Linux
OSX
Installation:
DOWNLOAD
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
