Houdini crash at saving file Octane 2018.1.0.3
Posted: Thu Mar 07, 2019 5:25 am
Hello JuanJGOn,
Me again, i'm sorry,
so i can see the render in the IPR : i've jumped from frames to frames by 30 frames steps and everything is ok.
Then i was on my way final render so i've tried everything i could but nothing can resolve my problem : houdini crash just at the saving file moment,
the renderer does its render but then at 97% it crash the app. > Denoiser ? MB ? i don't know/.
It happens for one image render or for a seq / with Mplay or without .
My two cents : denoiser : but it works in the IPR previews so that might not be that.
MB ? may be i've added a trail node to compute velocity but that might not be the process for octane.
All the computationnal CPU parts regarding geo are cached (53 go).
I have a shader with both a rgb attribute and a float attribut : new stuff
Let's try to find a solution without the file if possible cause 53 go is a bit too much for a transfer and without caching the geo would be like 10 mn of wait to be seen in the scene.
You will see several errors in the following log file :
Here they are :
05:57:26 ERROR: [materials] --------- Material SHOP node "" not found (not important i guess)
05:57:35 ERROR: [materials] --------- Material SHOP node "" not found (not important i guess)
05:57:36 ERROR: [rt vop] ------------ The Octane node has not been found in the linked node (??)
And here is the log file in all its glory :
Log started Thu Mar 7 05:57:18 2019
Octane Render for Houdini by Juanjo Gonzalez. Build 2018.1.0.3 (Build date: Jan 31 2019 00:31:38)
Octane API: 2018.1 RC3
HDK API: 17.0.459
Houdini host version: 17.0.483
System: GenuineIntel unknown, 3190 Mhz., 16 cores
OS: Windows 8 64-bit
05:57:18 INFOR: [license] ----------- This Octane License is already active
05:57:18 INFOR: [system] ------------ Setting the GPUs device state and priority
05:57:18 INFOR: [driver] ------------ Initializing a Houdini driver for the Octane MPlay viewport
05:57:18 INFOR: [driver] ------------ MPlay lock file: C:/Users/PC/Documents/houdini17.0/.flipbook_lock.arnold
05:57:18 INFOR: [core] -------------- ROP node render, time 0.00
05:57:18 INFOR: [loader] ------------ Houdini camera path: /obj/cam2
05:57:19 INFOR: [core] -------------- Render layers disabled
05:57:19 INFOR: [loader] ------------ Houdini camera path: /obj/cam2
05:57:19 INFOR: [driver] ------------ Opening Houdini driver for the Octane viewport
05:57:19 INFOR: [driver] ------------ Diver size 1920 x 1080
05:57:25 INFOR: [loader] ------------ Loading scene
05:57:25 INFOR: [loader] ------------ Found a OBJ node: /obj/cam2
05:57:25 INFOR: [loader] ------------ Found a OBJ node: /obj/VIDEO_RENDER
05:57:25 INFOR: [loader] ------------ Render SOP for this node: /obj/VIDEO_RENDER/VIDEO_RENDER, name VIDEO_RENDER
05:57:25 INFOR: [loader] ------------ Found a OBJ node: /obj/CABLES_RENDER
05:57:25 INFOR: [loader] ------------ Render SOP for this node: /obj/CABLES_RENDER/CABLES_RENDER, name CABLES_RENDER
05:57:25 INFOR: [loader] ------------ Found a OBJ node: /obj/source_particles
05:57:25 INFOR: [loader] ------------ Render SOP for this node: /obj/source_particles/OUT_PARTICLES, name OUT_PARTICLES
05:57:25 INFOR: [loader] ------------ Found a OBJ node: /obj/octane_light1
05:57:25 INFOR: [loader] ------------ Render SOP for this node: /obj/octane_light1/switch3, name switch3
05:57:25 INFOR: [materials] --------- Building the materials list
05:57:25 INFOR: [materials] --------- Found 2 materials
05:57:26 INFOR: [loader] ------------ Transformation matrix for MB step 0
05:57:26 INFOR: [loader] ------------ Transformation matrix for MB step 1
05:57:36 INFOR: [loader] ------------ Transformation matrix for MB step 0
05:57:36 INFOR: [loader] ------------ Transformation matrix for MB step 1
05:57:36 INFOR: [loader] ------------ Building the render target
05:57:36 INFOR: [loader] ------------ Loading the Houdini camera parameters
05:57:36 INFOR: [loader] ------------ Houdini camera path: /obj/cam2
05:57:36 INFOR: [loader] ------------ Scene Loaded
05:57:36 INFOR: [loader] ------------ Setting the motion blur parameters
05:57:36 INFOR: [preview image] ----- Set image callback
05:57:36 INFOR: [render] ------------ Render setup, set renderTarget and update
05:58:04 INFOR: [render progress] --- 1 percent, Samples 36 of 2500, R.Time 00:00:06, MSamples/Sec. 11.04
05:58:06 INFOR: [render progress] --- 2 percent, Samples 52 of 2500, R.Time 00:00:08, MSamples/Sec. 13.15
05:58:08 INFOR: [render progress] --- 3 percent, Samples 76 of 2500, R.Time 00:00:10, MSamples/Sec. 19.05
05:58:10 INFOR: [render progress] --- 4 percent, Samples 100 of 2500, R.Time 00:00:12, MSamples/Sec. 21.16
05:58:13 INFOR: [render progress] --- 5 percent, Samples 132 of 2500, R.Time 00:00:15, MSamples/Sec. 21.79
05:58:17 INFOR: [render progress] --- 6 percent, Samples 172 of 2500, R.Time 00:00:19, MSamples/Sec. 23.69
05:58:21 INFOR: [render progress] --- 8 percent, Samples 216 of 2500, R.Time 00:00:23, MSamples/Sec. 22.60
05:58:26 INFOR: [render progress] --- 10 percent, Samples 272 of 2500, R.Time 00:00:28, MSamples/Sec. 23.22
05:58:31 INFOR: [render progress] --- 13 percent, Samples 332 of 2500, R.Time 00:00:33, MSamples/Sec. 23.41
05:58:37 INFOR: [render progress] --- 16 percent, Samples 400 of 2500, R.Time 00:00:39, MSamples/Sec. 24.22
05:58:44 INFOR: [render progress] --- 18 percent, Samples 468 of 2500, R.Time 00:00:46, MSamples/Sec. 21.65
05:58:52 INFOR: [render progress] --- 22 percent, Samples 552 of 2500, R.Time 00:00:54, MSamples/Sec. 22.52
05:59:00 INFOR: [render progress] --- 25 percent, Samples 644 of 2500, R.Time 00:01:02, MSamples/Sec. 22.55
05:59:10 INFOR: [render progress] --- 29 percent, Samples 748 of 2500, R.Time 00:01:12, MSamples/Sec. 23.04
05:59:20 INFOR: [render progress] --- 34 percent, Samples 860 of 2500, R.Time 00:01:22, MSamples/Sec. 22.71
05:59:31 INFOR: [render progress] --- 39 percent, Samples 980 of 2500, R.Time 00:01:34, MSamples/Sec. 22.20
05:59:44 INFOR: [render progress] --- 44 percent, Samples 1112 of 2500, R.Time 00:01:46, MSamples/Sec. 22.97
05:59:57 INFOR: [render progress] --- 50 percent, Samples 1256 of 2500, R.Time 00:01:59, MSamples/Sec. 22.97
06:00:12 INFOR: [render progress] --- 56 percent, Samples 1412 of 2500, R.Time 00:02:14, MSamples/Sec. 21.55
06:00:27 INFOR: [render progress] --- 63 percent, Samples 1580 of 2500, R.Time 00:02:29, MSamples/Sec. 22.39
06:00:44 INFOR: [render progress] --- 70 percent, Samples 1760 of 2500, R.Time 00:02:46, MSamples/Sec. 22.09
06:01:01 INFOR: [render progress] --- 78 percent, Samples 1952 of 2500, R.Time 00:03:03, MSamples/Sec. 23.04
06:01:20 INFOR: [render progress] --- 86 percent, Samples 2156 of 2500, R.Time 00:03:22, MSamples/Sec. 23.21
06:01:40 INFOR: [render progress] --- 95 percent, Samples 2376 of 2500, R.Time 00:03:42, MSamples/Sec. 22.98
06:01:50 INFOR: [render progress] --- 100 percent, Samples 2500 of 2500, R.Time 00:03:52, MSamples/Sec. 0.00
06:01:51 INFOR: [render stats] ------ Objects: 2, Triangles: 13248012, Hairs: 0, Voxels: 0, Particles: 0
06:01:51 INFOR: [render stats] ------ Textures (8/16/32/64): 0 / 0 / 0 / 2
06:01:51 INFOR: [render stats] ------ GPU RAM (used/free/total): 4471 / 4557/ 11264 [MB]
06:01:51 INFOR: [render stats] ------ Sys RAM (used/free): 34054 / 130971, Total mem. used: 27215 [MB]
06:01:51 INFOR: [render stats] ------ Out-of-core RAM (used/max) 0 / 16384 [MB]
06:01:51 INFOR: [render stats] ------ Local GPUs: 4, Net GPUs: 0, Net memory: 0 [MB]
06:01:51 INFOR: [preview image] ----- Reset image callback
06:01:51 INFOR: [final image] ------- Get the final complete Octane image
06:01:51 INFOR: [final image] ------- Reading final HDRI image
06:01:51 INFOR: [save image] -------- Save image function enabled
06:01:51 INFOR: [save image] -------- Saving the "Denoised beauty" pass to the "E:/PERSO/VFX_SCHOOL/WEEK-1/week_1_01/render/week-1-exercise2-6.Octane_ROP1-6.0001" file
Been working on this for 18hrs non stop time to have some sleep but no renders
Thank you JuanJo,,
Here they are :
HDK API: 17.0.459
Thank you JuanJo,,
