Pls Help Remove noise!
Posted: Sun Feb 24, 2019 10:59 am
by Skodry
Guys, I can not remove from the red noise that is clearly visible on the glass and black stand for the circle. Can you help me pls?
Sorry for grammar mistakes, used google translator
Re: Pls Help Remove noise!
Posted: Mon Feb 25, 2019 4:20 pm
by bepeg4d
unfortunately the image you have shared is not visible.
Please use the Upload attachment button instead.
ciao Beppe
Posted: Tue Feb 26, 2019 7:17 am
by Skodry
bepeg4d wrote:Hi,
ciao Beppe
Posted: Thu Feb 28, 2019 6:00 am
by Skodry
bepeg4d wrote:Hi,
ciao Beppe
I do not understand how it works. But the picture can sometimes not be displayed. Can I just attach a link to the screenshot?
https://prnt.sc/mq733j
I need to remove the red noise on the glass of coffee (seen on the right side of the glass). The noise is also clearly visible behind the lifebuoy on a black stand.
I see that this noise is from OctaneDayLight and Emission, but I cannot remove them, they create the lighting I need.
Changing the value of the parameter Diffuce depth and Specular Depth does not solve my problem
Emission (screenshot) -
https://prnt.sc/mr65dl
Octane setting (screenshot) -
https://prnt.sc/mr630c
Help Pls :3
Posted: Wed Mar 06, 2019 8:54 am
by bepeg4d
the residual noise is caused by the geometry emitter.
You can rise the Max Samples to 8.000, and enable Adaptive sampling to solve, or switch to v4 with AI Denoiser with far less samples.
Please reduce the Diffuse and Specular depth to default values, and increase Parallel Samples and Max tile to speed up the rendering.
You can also set the GI Clamp at 10, without changing the light behavier, and reduce noise.
ciao Beppe
