Cinema 4D version 2018.1-RC4 (Test version)
Posted: Wed Feb 20, 2019 3:22 pm
Hi All,
This is the first test release of the plugin which is based on 2018.1-RC4 SDK and matches OctaneRender Standalone 2018.1-RC4.
As with all experimental releases, please do not use this for production purposes. 2018.1 XB2 will expire in 60 days
New features
To learn more about the new features and improvements of OctaneRender 2018.1, please check out the 2018.1 release post, but this a quick list of the main new features that have been added:
NV Link support on RTX 2080 and RTX 2080 Ti
Cryptomatte. It's working with new EXR(Octane) format type. In this type you cannot use render masks but you will not need to use with Crypto mattes.
Vertex Attributes in the mesh objects. It's used for vertexmap and vertexcolor emulation.
New "Color Vertex Attribute" and "Float Vertex Attribute" nodes to retrieve the vertex attributes in the shaders.
Way less Volume Render Noise. New option in the kernels to disable this feature if the matching of the Octane v4 volumes is needed.
Direct Levelset surface rendering. New option in the Octane volumetrics custom object plugin to configure the OpenVDB rendering to work with SDFs and assign their Octane material nodes.
Scatter depth limiting (i.e. fast fog rendering)
Overall 5% faster than V4 stable (about 315 OB vs 298 OB in our tests)
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 387 or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
IN ANY CRASH CASE PLEASE DO THESE!!!
If you see CUDA errors follow 1,2,3,4.
1- Try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
2- Check GPU frequency. Overclocking would cause instability issues
3- Check PSU. Insufficient power output would cause instability issues
4- Check the free amount of GPU's VRAM and system's RAM while working. Low VRAM will/may cause CUDA errors. Be aware of some generator objects will have different triangle count in Picture Viewer than Live Viewer. It’s like “editor/render” parameter. Just try to use the same value. Also try to optimize your scene for polygon count, even use smaller images. Try to use Octane texture nodes rather than using C4D texture/shaders.
Alternatively, use V4 and Out-of-core(OOC) function. Increase RAM for OOC and It should not exceed physical RAM amount. Check TDR value and increase if it's necessary.
5- If you see C4D crashes without CUDA errors, then send us bugreport.zip, screen-shots and video capture to show process and crash moment. Also please send us a sample scene in a format of C4D or ORBX to let us investigate and test it. Alternatively, try to delete/hide some objects/materials until crash gone away. If you find what's causing crashes, send us a sample scene to let us for investigating and bring a fix or solution.
Thanks for helping the development by your feedbacks! It’s impossible to quickly catch every case without user feedbacks! It’s the same procedure as other companies do like Maxon/etc...
Change list
Having all fixes/improvements of 4.02.1-R3 since 2018.1-RC1 and also SDK 2018.1-RC4 features
Changes of V4.02.1-R3
- Fix: brdf type in octane materials come from old scenes.
- Fix: Missing parts for saved blend material in livedb.
Changes of V4.02.1-R2
- single file for each render layer with Octane-EXR type. It's well on exr compression.
- fix: search function of livedb manager
- fix: Brdf change issue with V1/V2 materials on V4. viewtopic.php?f=85&t=70622#p356762
- small fixes over 4.02.1
Changes of V4.02
- Better log outputs
- Missing light render passes(directs/indirects)
- Several minor fixes in plugin and core side(See standalone topic)
- Bugfix: crash on exportORBX command if you don't have LiveViewer on startup layout
- extended connection api for 3rd parties
- commandline/nogui support on -exportORBX commandline parameter
- UDIM(Image Tiles texture) support
- HDRLS connection bridge
- Missing DeMain pass in Octane-EXR option
Changes of 2018.1-RC1.1
- Icon for vectron
- Fix: Interactive performance problem with many objects
- Preview problems of octane materials
- Fix: Wrong brdf list with specular/universal materials
Changes of V4.01.1-R1
- Better display performance in LiveViewer
- Fix: Only displaying the vram stats for gpu0
- Minor speed improvement on scene preparation in animation rendering
- Fix: Show in Picture Viewer command
- Fix: Missing clones order in Scatter object with CSV mode
- Fix: Missing default value in Triplanar's coordinate space
Changes of V4.00-R1
Fix: Texture tangent and some info passes in render settings
- Planetary environment.
- Orbx proxy object.
- Fix: Unrecognized channel names in vdb file. viewtopic.php?f=30&t=69481#p350342
- No need to activate denoiser from SettingsWindow or cameraImager for getting denoising passes working in Picture Viewer
- Fix: Missing network render option for Studio builds.
- Fix: Wrong swap for objects/lights in Picture Viewer rendering when you have visibility animations.
- Fix: Extra beauty/denoising passes with RenderLayerMasks
Changes of V4.00
Fix: instanceID problem geometry objects
Fix: A crash case in motion blur
Fix: Several core fixes for Cuda crashes
- Manual revisions for V4 features
WINDOWS REGULAR BUILD (R16-R20)
https://render.otoy.com/customerdownloa ... C4-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R16-R20)
OSX REGULAR BUILD (R15-R20)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R20)
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053). Otherwise, the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by the firewall and any antivirus software.
-Updated Nvidia drivers(most recent like 39x.x) with Cuda 9.1 - change driver versions if you have much trouble with the current driver
ONLINE HELP MANUAL
Use embedded help buttons from Octane nodes and windows
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First, remove all octane related stuff from plugins and the main folder of Cinema4D.
Also, download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
ORBX EXAMPLE VIDEO
https://vimeo.com/302046063
Node sliders
https://vimeo.com/268974364
Viewport rendering mode
https://vimeo.com/265747658
https://vimeo.com/265294205
New features
Change list
Changes of V4.02
- Icon for vectron
Changes of V4.00-R1
Changes of V4.00
Requirements:
ONLINE HELP MANUAL
Installation
ORBX EXAMPLE VIDEO
Node sliders
