OSL texture issue / Working with parallax mapping
Posted: Sun Dec 02, 2018 7:04 pm
Greetings. My name is Alex, i am concept artist and kinda far away from coding and scripting nature. I would like to ask somebody to help me with this code:
This code from tutorial i've bought and it makes parallax mapping effect for a entire quad polygon or plane mesh while it works in Octane stand-alone version.. And it works fine there.
Once i've trying to jump into Octane plugin for Modo, create material for plane, assign Octane override, connect OSL texture node to diffuse channel in auto-created Glossy Material and then load this code into OSL texture node, there is Error pop-out:
Channel modifier type not found for Octane node type 88
I press ok and it offers to me to create channel modifier. And my problem is that I don't know what exactly i have to create. I did some research, but since i am not a coder or script writer at all, i can't figure out myself how to run this script properly in Octane Plug-in for Modo.
I read through the code as far as i can and can't see where this code takes source Texture/Image to apply parallax mapping effect on it.
Can anyone help me to figure out how to execute this script properly in Octan plugin for Modo?
Here is a short video step-by-step i've done and its self-explained.
https://youtu.be/CPFoRsO-4Vk
Here is a texture, that used by this script: http://exeshe4ki.com/mt-content/uploads ... map_03.png
Thank you.
#include <stdosl.h>
shader ParallaxInterior(
int zUpAxis = 0 [[ string widget = "boolean" ]],
string filename = "" [[ string widget = "filename" ]],
int textureFlip = 0 [[ string widget = "boolean" ]],
int textureFlop = 0 [[ string widget = "boolean" ]],
float roomDepth = 1 [[ float min = 0.1, float max = 100 ]],
float widthOverscan = 0 [[ float min = 0.0, float max = 0.9 ]],
float heightOverscan = 0 [[ float min = 0.0, float max = 0.9 ]],
int enableMidground = 0 [[ string widget = "boolean" ]],
float midgroundDepth = 0.5 [[ float min = 0.05, float max = 99 ]],
float midgroundOffsetX = 0,
float midgroundOffsetY = 0,
int enableCurtains = 0 [[ string widget = "boolean" ]],
output color outRGB = 0.0,
//user controls remapping
float roomDepthMult = clamp(roomDepth,0.1,100);
float heightOverscanMult = 1 - clamp(heightOverscan,0,0.9);
float widthOverscanMult = 1 - clamp(widthOverscan,0,0.9);
float midgroundDepthMult = clamp(midgroundDepth,0.05,roomDepthMult-0.01);
float midgroundOffY = midgroundOffsetY * (textureFlip*2-1) * 0.1;
float midgroundOffX = midgroundOffsetX * (textureFlop*2-1) * 0.1;
//global variables & remapping
vector objI = transform("object", -I);
if (zUpAxis > 0){
objI = vector(-objI[0],-objI[1],-objI[2]) * color(widthOverscanMult, heightOverscanMult, 1); //reorder to match UV for Y up axis
} else {
objI = vector(-objI[0],objI[2],-objI[1]) * color(widthOverscanMult, heightOverscanMult, 1); //reorder to match UV for Z up axis
color objPOrig = (color(u,v,0.5) * 2 - 1) * 0.5 + 0.5; //for curtains
color objP = (color(u,v,0.5) * 2 - 1) * color(widthOverscanMult, heightOverscanMult, 1) * 0.5 + 0.5; //UV seems to be the better approach
//bases for width/height/depth
vector sections = step(0, objI);
color baseDepth = (objP-sections)/(-objI * roomDepthMult);
color mgDepth = (objP-sections)/(-objI * midgroundDepthMult);
color baseBack = (objP-sections)/(-objI);
color baseWidth = baseDepth * roomDepthMult;
//depth and width ramps
color baseDepthX = (baseDepth[1]*objI+objP + 1);
color baseDepthY = (baseDepth[0]*objI+objP + 1);
color baseWidthX = (baseWidth[1]*objI+objP + 1);
color baseWidthY = (baseWidth[0]*objI+objP + 1);
float horizU = baseDepthY[2] - 0.5;
float vertU = baseWidthX[0] - 1;
float horizV = baseWidthY[1] - 1;
float vertV = baseDepthX[2] - 0.5;
//convert ramps to UV/ST... WIP - not very efficient
float sideWallsMask = step(0,horizU) * step(0,1-max(horizV, 1-horizV));
color sideWallsUV = color(horizU, horizV, 0) / 3;
color rWallUV = (sideWallsUV + color(2.0/3.0, 1.0/3.0, 0)) * sideWallsMask * sections[0];
color lWallUV = (sideWallsUV + color(0.0, 1.0/3.0, 0)) * sideWallsMask * (1-sections[0]);
lWallUV[0] = (1.0/3.0 - lWallUV[0]) * sideWallsMask * (1-sections[0]);
float FloorCeilMask = step(0,vertV) * step(0,1-max(vertU, 1-vertU));
color FloorCeilUV = color(vertU, vertV, 0) / 3;
color ceilUV = (FloorCeilUV + color(1.0/3.0, 2.0/3.0, 0)) * FloorCeilMask * sections[1];
color floorUV = (FloorCeilUV + color(1.0/3.0, 0, 0)) * FloorCeilMask * (1-sections[1]);
floorUV[1] = (1.0/3.0 - floorUV[1]) * FloorCeilMask * (1-sections[1]);
color backWallUV = ((baseBack[2]*objI + (objP/2)/(roomDepthMult)) * (roomDepthMult*2) / 3 + color(1.0/3.0, 1.0/3.0, 0) ) * (1 - max(step(0,horizU), step(0,vertV)));
color midgroundUV = (1.0/3.0 - (baseBack[2]*objI + (objP)/(midgroundDepthMult*2)) * (midgroundDepthMult*2) / 3);
float midgroundMask = step( 0, midgroundUV[1] * 3 * (1-midgroundUV[1]*3) ) * step( 0, midgroundUV[0] * (1.0/3.0-midgroundUV[0]) );
midgroundUV = (color(midgroundOffX, midgroundOffY, 0) + midgroundUV) * midgroundMask;
midgroundUV[1] = 1-midgroundUV[1];
color curtainsUV = objPOrig * color(1.0/3.0, 1.0/3.0, 1);
curtainsUV[0] = 1.0/3.0 - curtainsUV[0];
color finalUV = ceilUV + floorUV + rWallUV + lWallUV + backWallUV;
//flipping ctrl
if (textureFlop > 0){
midgroundUV[0] = 1.0/3.0 - midgroundUV[0];
}else
finalUV[0] = 1-finalUV[0];
if (textureFlip > 0){
finalUV[1] = 1-finalUV[1];
midgroundUV[1] = 1 - midgroundUV[1] + 2.0/3.0;
curtainsUV[1] = 1.0/3.0 - curtainsUV[1];
color roomRGB = texture(filename, finalUV[0], finalUV[1]);
color finalRGB;
//midground switch
if (enableMidground > 0){
float midgroundA;
color midgroundRGB = texture(filename, midgroundUV[0], midgroundUV[1], "alpha", midgroundA);
finalRGB = mix(roomRGB,midgroundRGB,midgroundA);
else{
finalRGB = roomRGB;
//curtains switch
if (enableCurtains > 0){
float curtainsA;
color curtainsRGB = texture(filename, curtainsUV[0], curtainsUV[1], "alpha", curtainsA);
finalRGB = mix(finalRGB,curtainsRGB,curtainsA);
outRGB = finalRGB;
}Once i've trying to jump into Octane plugin for Modo, create material for plane, assign Octane override, connect OSL texture node to diffuse channel in auto-created Glossy Material and then load this code into OSL texture node, there is Error pop-out:
Thank you.
