[Bug] Accessing LiveDB causes OctaneServer to crash on macOS
Posted: Fri Nov 30, 2018 8:09 am
by davorin
With the new version 4 OctaneRender for Blender I get assigning a material from the LiveDB to a cube in Blender:
Octane: ERROR starting frame load.
Octane: uploading ERROR.
Octane: ERROR loading camera.
Octane: ERROR setting render region.
Octane: ERROR loading mesh.
Octane: ERROR deleting mesh.
Octane: ERROR loading materials of transform.
Octane: ERROR loading transform.
Octane: ERROR loading render passes.
Octane: ERROR loading kernel.
Octane: ERROR setting GPUs on render server.
Octane: ERROR finishing frame load.
Octane: ERROR starting render.
And OctaneServer crashes immediately with:
Octane Engine v. 16.3
Octane: Starting Octane engine...
Work Scheduler initializing 8 worker threads
Octane: ...started
Octane: Activating license...
Octane: ...activated
Octane: LiveDB cache refresh started...
Octane: LiveDB cache refresh complete
Segmentation fault: 11
This happens with the new yearly subscription license....
Re: [Bug] Accessing LiveDB causes OctaneServer to crash on macOS
Posted: Fri Nov 30, 2018 9:37 am
by J.C
On my side Blender is crashing, quits itself when trying to assign a material from Live DB.
Posted: Sat Dec 01, 2018 3:16 pm
by davorin
Opened another ticket with OTOY (o;
Blender just quits with:
Crash log:
# Blender 2.79 (sub 0), Commit date: 1970-01-01 00:00, Hash unknown
bpy.context.area.type = 'MAT_LIVEDB' # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value = (0.565762, 0.947762, 0.99, 1) # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value = (0.780449, 0.99, 0.97581, 1) # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value = (0.828418, 0.99, 0.947323, 1) # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value = (0.952361, 0.99, 0.9435, 1) # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[2].default_value = 0.2 # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value[0] = 1 # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value[1] = 1 # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value[2] = 1 # Property
bpy.data.node_groups["Shader Nodetree"].nodes["Octane Specular Material"].inputs[1].default_value = (1, 1, 1, 1) # Property
# backtrace
0 blender 0x00000001077651ea BLI_system_backtrace + 58
1 blender 0x0000000106cabe7a sig_handle_crash + 362
2 libsystem_platform.dylib 0x00007fff598a2f5a _sigtramp + 26
3 ??? 0x0000000000000001 0x0 + 1
4 blender 0x00000001072f7a46 mywrite + 422
5 blender 0x00000001072fff04 write_node_socket + 196
6 blender 0x00000001072ff3be write_nodetree_nolib + 302
7 blender 0x00000001072f350d write_file_handle + 18477
8 blender 0x00000001072f788e BLO_write_file_mem + 30
9 blender 0x000000010738f728 BKE_undo_write + 424
10 blender 0x0000000106e3ec2c ED_undo_push + 188
11 blender 0x0000000106ebe471 ui_apply_but_funcs_after + 609
12 blender 0x0000000106eb9e07 ui_region_handler + 471
13 blender 0x0000000106cb862f wm_handlers_do_intern + 1199
14 blender 0x0000000106cb4afc wm_handlers_do + 28
15 blender 0x0000000106cb4642 wm_event_do_handlers + 2370
16 blender 0x0000000106caca10 WM_main + 32
17 blender 0x0000000106ca8bec main + 1036
18 blender 0x0000000106ca87d4 start + 52
Posted: Sat Dec 01, 2018 3:44 pm
by davorin
Or this one:
blender(59301,0x70000c8fd000) malloc: *** error for object 0x7f911f20bc90: incorrect checksum for freed object - object was probably modified after being freed.
*** set a breakpoint in malloc_error_break to debug
Abort trap: 6
Posted: Sun Dec 02, 2018 3:14 pm
by DrawFun
Hi all,
Thanks for your reports.
Currently we are working on a refactored LiveDB system(integrating with both liveDB and localDB) for blender.
Could you please give me a bit more information about the crash?
e.g. did it happen randomly? or just in some specific situations(downloading some specific materials)
Cheers,
DrawFun
Posted: Sun Dec 02, 2018 3:59 pm
by davorin
Well it happened most of the time assigning water material from LiveDB....
When I restarted OctaneServer then I could assign it just one time...
Sadly there not much information on the console....just those messages...
Is there a way to dump all LiveDB material for local storage? So OctaneServer only downloads changed or new materials?
Also I don't know what is the best way to move a blender design to another host...as all LiveDB material is lost...you have to re-assign it for every object...
