				Phoenix ocean/water mesh  and octane
				Posted: Fri Oct 19, 2018 10:37 pm
				by coilbook
				For some reason this new octane has problem rendering phoenix ocean mesh or any liquid mesh.  One frame it renderers next one it does not.  The liquid mesh is missing.  Then it can appear and disappear..   Thanks
it has something to do with displacement phoenix texture.  I am using 3.11.04 Nightly, Build ID: 2018100328568
scene link
https://we.tl/t-80GdtMtHuv
   please go to frame 1330   and see with rendering>displacement on and off
				Re: Phoenix ocean/water mesh  and octane
				Posted: Mon Oct 22, 2018 12:44 pm
				by paride4331
				coilbook wrote:For some reason this new octane has problem rendering phoenix ocean mesh or any liquid mesh.  One frame it renderers next one it does not.  The liquid mesh is missing.  Then it can appear and disappear..   Thanks
scene link
Hi coilbook,
It seems 3.08 and 6.08 render in the same way your file.
Are you usign 3dsmax 2019? What about using 3dsMax 2018?
				Posted: Mon Oct 22, 2018 2:45 pm
				by coilbook
				paride4331 wrote:coilbook wrote:For some reason this new octane has problem rendering phoenix ocean mesh or any liquid mesh.  One frame it renderers next one it does not.  The liquid mesh is missing.  Then it can appear and disappear..   Thanks
scene link
Hi coilbook,
Hi Paride,
 I am using 2018.4 3ds max.    You said "It seems 3.08 and 6.08 render in the same way your file."  is the problem related to textures? Were you able to reproduce the problem.  It seems that when I xref the liquid grid the problem goes away.  THanks
				Posted: Tue Oct 23, 2018 7:27 am
				by paride4331
				Hi coilbook,
I have no idea because you did not share any texture with your file, so it's a little bit difficult to understand the scene if it is right while rendering.
				Posted: Tue Oct 23, 2018 7:50 pm
				by coilbook
				paride4331 wrote:Hi coilbook,
Hi Paridie
it is not about the textures.  If you go to frame 1330 you will see there is no liquid mesh appearing. Thank you
				Posted: Wed Oct 24, 2018 9:00 am
				by paride4331
				Hi coilbook,
this?
