16.2.4 Linux displacement issue
Posted: Fri Sep 21, 2018 5:24 am
by grimm
Hi Guys,
16.2.4 has a strange issue with displacement (the ground plane):
Here is how it looks when rendered on previous versions:
Jason
Re: 16.2.4 Linux displacement issue
Posted: Fri Sep 21, 2018 5:35 am
by grimm
Just wanted to add that it's the same in the viewport as well:
The displacement is just on a simple UV unwrapped plane.
Jason
Posted: Fri Sep 21, 2018 10:10 pm
by linograndiotoy
Hello Jason!
Would it be possible for you to share you scene (no spider needed!) so developers can test it and understand what's wrong?
Posted: Sat Sep 22, 2018 4:23 am
by grimm
Hi linograndiotoy,
I think I have figured out the issue. It looks like when 16.2.4 reads in an older version's blend file, it doesn't set the displacement node parameters correctly. You can see here that there are two items that are not being set and must default to a lower value.
If I then set the displacement level parameter correctly 4096x4096, the displacement looks correct again:
Just to test I set the level to a very low value and it looks bad again:
Jason
Posted: Sat Sep 22, 2018 6:44 am
by linograndiotoy
Thanks for you reply.
