OctaneRender™ for Blender 3.08 - 15.2.5 [OBSOLETE]
Posted: Tue Jul 03, 2018 3:45 am
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
NEW FEATURES SINCE LAST RELEASE
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 3.08 here:
viewtopic.php?f=33&t=63219
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 15.2.5 (2.79)
Octane Server - 15.2.5
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v15.2.5 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v15.2.5 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v15.2.5 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Add sheen roughness for metal/glossy materials
- Add a button for emptying GPU
- Add user preference to empty GPU after render automatically
- Use enum values for displacement and falloff nodes
- Do not reload scene when turn on/off camera imager
- Support larger max width for nodes
- Support back compatibility for transmission color connection in specular material
- Support back compatibility for projection mode
- Support back compatibility for camera imager
- Hide legacy sockets in surface panels
- Fix the livedb crash of gradient texture
- Fix the livedb crash when updating and drawing node tree at the same time
- Fix camera imager UI grey out issue
- Fix medium node connection failure in specular materials
Windows
Linux
Installation:
$ OctaneServer &Blender Octane Edition - v15.2.5 Linux
OSX
Installation:
DOWNLOAD
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
