Page 1 of 2
Help with Understanding Displacement
Posted: Sat Jun 23, 2018 8:01 pm
by RSgraphics
Hey everyone.
I have a project due Monday. Very simple scene (download attached). Its a parametric cube and I'm having the following issues:
1. Once I bevel the edges, the displacement map separates at the edges. I understand this is because I'm breaking the UV's once I bevel and tried using box mode but that just makes every side of the box have the displacement instead of just the front face. I've tried making the object editable and selecting just the front polygons but i still get the funky edges.
I'm hoping someone can download the scene and fix the Displacement to only show on one side and to have nice edges and also explain if my work flow is incorrect.. I uploaded my file and screen shots to help.
Thank you,
Robert.
OTOY HELP.zip
File for Review
(80.21 MiB) Downloaded 282 times
Re: Help with Understanding Displacement
Posted: Sat Jun 23, 2018 8:02 pm
by RSgraphics
Here are the screen shots
Posted: Sat Jun 23, 2018 9:09 pm
by jayroth
Displacements in Octane can be a little tricky at times. In this case, the parametric cube is part of the problem, as the face vertexes of the cube are NOT welded together. You will need to convert your cube to an editable object, and optimize your points. This will weld the cube into a single cohesive object, which Octane will have better luck displacing. That said, there are still potential issues, to my recollection. You might need to adjust the displacement midpoint option to either 0 or 1 (defaults to 0.5). That should get you mostly there, but you may still have trouble. Searching the Cinema forums for displacement will get you more information.
Good luck!
Posted: Sat Jun 23, 2018 10:07 pm
by niestudio
try changing this displacement dropdown to follow geometric normal.
It closes the gaps here
Posted: Sat Jun 23, 2018 11:10 pm
by RSgraphics
jayroth wrote:Displacements in Octane can be a little tricky at times. In this case, the parametric cube is part of the problem, as the face vertexes of the cube are NOT welded together. You will need to convert your cube to an editable object, and optimize your points. This will weld the cube into a single cohesive object, which Octane will have better luck displacing. That said, there are still potential issues, to my recollection. You might need to adjust the displacement midpoint option to either 0 or 1 (defaults to 0.5). That should get you mostly there, but you may still have trouble. Searching the Cinema forums for displacement will get you more information.
Good luck!
Yeah I tried all the usual settings. But this is beyond that. I tried with and without parametric objects and both had similar issues. The C4D cube is auto welded together by C4D. However a cylinder wont be auto welded as you described.
Posted: Sat Jun 23, 2018 11:11 pm
by RSgraphics
niestudio wrote:try changing this displacement dropdown to follow geometric normal.
Niestudio, which version are you running? Im using C4DR16 and octane 3.08. My version doesnt have that menu selection.
Posted: Sun Jun 24, 2018 12:08 am
by niestudio
I'm on 3.08 too, but R17. Not sure if there's a difference from R16 to R17.
Can you post a screenshot of your displacement tab?
Posted: Sun Jun 24, 2018 1:04 am
by RSgraphics
Here you go
Posted: Sun Jun 24, 2018 1:10 am
by niestudio
Perhaps you have an older release of 3.08
Posted: Sun Jun 24, 2018 1:17 am
by RSgraphics
Oh i see. Its 3.06.
Im a little hesitent to upgrade. Dang maybe i should go for it.
